SizeOf built-in function?
TodWulff
Post by TodWulff » Fri Oct 12, 2018 5:52 am
Is there a built-in function that returns the number of elements in a previously dim'd int, single, byte (or other sub-word variants) arrays?
Yeah, I know I can physically count the elements in the def statements and use that with a #def, but if I neglect to do so, or forget to update the #def that reflects the def'd array element count, then I have a potential issue.
I've been cogitating on how to implement something like this programmatically as a function, but am coming up empty handed for a robust solution. Had considered using addressof for the var name and the next dim'd var, doing the math to try to figure that out, but that is a house of cards that can come down pretty quickly, I perceive.
What caused this is my stoopid little speaker test program that plays the US National Anthem (Star-Spangled Banner) that I shamelessly raped from some arduino app dev's git repo (credits are in the sources):
The SPK_defs.lib file:
#ifndef SPK_defs
#define SPK_defs
' @file:		SPK_lib.bas
' @target:		ARMbasic v7 Target
' @language:	ARMbasic
' This lib file provides #defs and other support data for making use
' of a spkr hooked to a GPIO line - in this case, it is a K1206 piezo buzzer actually
' @author Tod Wulff
' @version 1.1 - 12Aug18
'	- Updated for current rev hardware
' @version 1.0 - 29Dec08
'	- original version
'------------------------ IO Definitions --------------------------------------
#ifdef LPC824
	#define		_SPK_IO_PORT			6
#elif defined LPC54102	' ARMdrino | ARMniobe
	#define		_SPK_IO_PORT			30
The SPK_support.lib file:
#ifndef SPK_support
#define SPK_support
#include "spk\SPK_defs.lib"
' @target:		ARMbasic circa 2018 Targets
' This lib file provides support routines for making use of a speaker hooked to
' a GPIO line - in this case, it is a K1206 piezo buzzer actually...
' @author Tod Wulff
'	Revised circa 2008 code for use with circa 2018 ARMbasic devices from Coridium
'    This revision effort led me to understand that each device type has different timing models.
'    and that I will need to revise this for additional devices, beyond the LPC800-DIP (w/ LPC824).
 ' Preprocessor used to assert hard-coded constants vs using variables
#define _SPK_SwpHiFreq 5000
#define _SPK_SwpLoFreq 0
#define _SPK_SwpFreqLoopStep 100
#define _SPK_SwpMaxVol 20
#define _SPK_SwpMinVol 0
#define _SPK_SwpVolStep _SPK_SwpMaxVol
#define _SPK_SwpDur 1 'mS
#define bleep spk_beep(1500,15,25)
#define bloop spk_beep(500,15,25)
#define blip spk_beep(10000,1,1)
' FREQ 0-10,000HZ, VOL 0-50, Dur in uS
function spk_beep(spk_beep_freq as integer, spk_beep_volume as integer, spk_beep_duration as integer) as integer
'print spk_beep_freq, spk_beep_volume, spk_beep_duration
	if(if((spk_beep_freq<=0)+(spk_beep_freq>10000),1,0)+if((spk_beep_volume<=0)+(spk_beep_volume>50),1,0)+if(spk_beep_duration<=0,1,0)) then return 1
	dim spk_beep_start, spk_pulse_start, spk_pulse_period, spk_pulse_hi, spk_pulse_lo as integer
	spk_pulse_period = 1000000/spk_beep_freq
	spk_pulse_hi = spk_beep_volume * (10000/spk_beep_freq)
	spk_pulse_lo = spk_pulse_period-spk_pulse_hi
	output(_SPK_IO_PORT)
	spk_beep_start = timer
	while timer-spk_beep_start < spk_beep_duration * 1000
		'in-lined durations of 1-4 us to get best representation considering loop overheads
		'on the 824.  need to throw this code at the other family members with a scope and
		'give it a bit more robustness (#def the diff targets' timing.).
		if spk_pulse_hi=1
			out(_SPK_IO_PORT) = 1
			out(_SPK_IO_PORT) = 0
		elseif spk_pulse_hi=2
		elseif spk_pulse_hi=3
		elseif spk_pulse_hi=4
		else
			spk_pulse_start = timer
			while timer - spk_pulse_start < spk_pulse_hi
		while timer - spk_pulse_start < spk_pulse_lo
	return 0
endfunction
sub spk_sweep()
	dim freq_, vol_ as integer
	FOR vol_ = _SPK_SwpMinVol TO _SPK_SwpMaxVol STEP _SPK_SwpVolStep
		FOR freq_ = _SPK_SwpLoFreq TO _SPK_SwpHiFreq STEP _SPK_SwpFreqLoopStep
			SPK_BEEP(freq_, vol_, _SPK_SwpDur)
		NEXT freq_
		FOR freq_ = _SPK_SwpHiFreq DOWNTO _SPK_SwpLoFreq STEP _SPK_SwpFreqLoopStep
		NEXT freq_
	NEXT vol_
	FOR vol_ = _SPK_SwpMaxVol DOWNTO _SPK_SwpMinVol STEP _SPK_SwpVolStep
		NEXT freq_
		NEXT freq_
	NEXT vol_
endsub
The SPK_notes.lib file:
 * Public Constants, for making music
 ' credits: https://github.com/Jianan-Li/misc-arduino-sketches/tree/master/LEDMusicPlayer
#define SPK_Mnotes	89	' # of notes herein
#define nB0  31
#define nC1  33
#define nCS1 35
#define nD1  37
#define nDS1 39
#define nE1  41
#define nF1  44
#define nFS1 46
#define nG1  49
#define nGS1 52
#define nA1  55
#define nAS1 58
#define nB1  62
#define nC2  65
#define nCS2 69
#define nD2  73
#define nDS2 78
#define nE2  82
#define nF2  87
#define nFS2 93
#define nG2  98
#define nGS2 104
#define nA2  110
#define nAS2 117
#define nB2  123
#define nC3  131
#define nCS3 139
#define nD3  147
#define nDS3 156
#define nE3  165
#define nF3  175
#define nFS3 185
#define nG3  196
#define nGS3 208
#define nA3  220
#define nAS3 233
#define nB3  247
#define nC4  262
#define nCS4 277
#define nD4  294
#define nDS4 311
#define nE4  330
#define nF4  349
#define nFS4 370
#define nG4  392
#define nGS4 415
#define nA4  440
#define nAS4 466
#define nB4  494
#define nC5  523
#define nCS5 554
#define nD5  587
#define nDS5 622
#define nE5  659
#define nF5  698
#define nFS5 740
#define nG5  784
#define nGS5 831
#define nA5  880
#define nAS5 932
#define nB5  988
#define nC6  1047
#define nCS6 1109
#define nD6  1175
#define nDS6 1245
#define nE6  1319
#define nF6  1397
#define nFS6 1480
#define nG6  1568
#define nGS6 1661
#define nA6  1760
#define nAS6 1865
#define nB6  1976
#define nC7  2093
#define nCS7 2217
#define nD7  2349
#define nDS7 2489
#define nE7  2637
#define nF7  2794
#define nFS7 2960
#define nG7  3136
#define nGS7 3322
#define nA7  3520
#define nAS7 3729
#define nB7  3951
#define nC8  4186
#define nCS8 4435
#define nD8  4699
#define nDS8 4978
And the SPK_TEST2.bas main file (this is the one that actually plays the National Anthem):
' plays the star spangled banner
#include "spk\SPK_support.lib"
#include "spk\SPK_notes.lib"
sub playmelody
'76 elements
const SPK_Mfreqs = {
  nF5,nD5,nAS4,nD5,nF5,nAS5,nD6,nC6,nAS5,nD5,nE5,nF5,
  nF5,nF5,nD6,nC6,nAS5,nA5,nG5,nA5,nAS5,nAS5,nF5,nD5,nAS4,
  nD6,nD6,nD6,nDS6,nF6,nF6,nDS6,nD6,nC6,nD6,nDS6,nDS6,
  nDS6,nD6,nC6,nAS5,nA5,nG5,nA5,nAS5,nD5,nE5,nF5,
  nF5,nAS5,nAS5,nAS5,nA5,nG5,nG5,nG5,nC6,nDS6,nD6,nC6,nAS5,nAS5,nA5,
  nF5,nF5,nAS5,nC6,nD6,nDS6,nF6,nAS5,nC6,nD6,nDS6,nC6,nAS5
'76 elements - durations: 2 = half note, and 8/3,4,6,8,12
const SPK_Mdurations = {
  6.0,12.0, 4.0, 4.0, 4.0, 2.0, 6.0,12.0, 4.0, 4.0, 4.0, 2.0,
  8.0, 8.0, 2.76, 8.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 4.0, 4.0,
  6.0,12.0, 4.0, 4.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0,
  4.0, 2.76, 8.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0,
  4.0, 4.0, 4.0, 8.0, 8.0, 4.0, 4.0, 4.0, 4.0, 8.0, 8.0, 8.0, 8.0, 4.0, 4.0,
  8.0, 8.0, 2.76, 8.0, 8.0, 8.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0
}'over the    land     of  the  free  and  the  home  of  the  brave
#define SPK_Melements (76-1) 	' the -1 adjust to a zero reference
#define SPM_MdefTempo 1500.0	'default tempo for this piece is 3000 - this is a denominator (larger # = slower tempo)
#define SPM_Volume	1			' 1 to 50 - a pseudo pwm approach - 25 a is 50% duty cycle.
dim i as integer
dim SPK_Mnote_duration as single
for i= 0 to SPK_Melements
SPK_Mnote_duration = SPM_MdefTempo/SPK_Mdurations(i)
SPK_BEEP(SPK_Mfreqs(i), SPM_Volume, (1*SPK_Mnote_duration))
wait(SPM_MdefTempo/SPK_Mdurations(i)*1.3)
out(32)=i and 1					'toggle the LED state with each note
print chr(if(i mod 2 = 0,"+","*")); '~
next i
endsub
MAIN:
output(32)						' i've an LED hooked to this gpio for visual feedback purposes only
playmelody
END
And here is the original spk_test.bas file I wrote when I was revising the spk_support.lib file:
MAIN:
dim int, freq_, vol_, dur_, lastfreq, lastvol, lastdur as integer
lastfreq = -1
lastvol = -1
lastdur = -1
'spk_sweep
	DO
		Print "Enter Freq (INT, 0-10000, <0 to exit): ";
		Debugin Freq_
		if Freq_ < 0 then exit
		if freq_ = 0 then freq_=if(lastfreq = -1, 2500, lastfreq)  ' default to 2500 or last freq
		Print Freq_;" Enter Volume (INT, 0-50): ";
		Debugin Vol_
		if Vol_ = 0 then Vol_=if(lastvol = -1, 25, lastvol)   ' default to 25 or last volume
		Print Vol_;" Enter Duration in MS (INT >0): ";
		Debugin Dur_
		if Dur_ = 0 then Dur_=if(lastdur = -1, 500, lastdur) ' default to 500 or last duration
		Print Dur_
		Print
doit:
		if(SPK_BEEP(FREQ_, VOL_, DUR_)) then Print "Error!"
		LastFreq = freq_
		LastDur = dur_
		lastvol= vol_
		Print
		Print
	LOOP
bloop
bleep
bloop
bloop
bleep
bloop
bloop
bleep
bloop
END
I'd like to be able to amend the music notes/duration arrays, and then be able to programmatically test to ensure same # of elements exist in both arrays at run-time, and have the playback loop automagically adjust to the size of the arrays at run-time.
Please advise if a sizeof exists and, if not, suggest a robust means to test an array to determine the # of elements. Thanks, in advance.
TodWulff
Re: SizeOf built-in function?
Post by TodWulff » Fri Oct 12, 2018 6:01 am
And yes, the 2nd piece I implement will be the Marine Corps Hymn...
Ooh Rah!
:D
Post by olzeke51 » Mon Dec 10, 2018 4:10 pm
Me, I would put the value in the index(0) position,
then use a 'terminator' character - as the last position or data
then run it through a for/next counting until the 'terminator' is encountered
[ascii control codes &H0 - &H1F might be a good choice - depending on your data style]
this would give you a count to compare with index(0).
'course now, my math can get messed up. on the indexing.
Just an idea.
BTW - I am shamelessly ripping off your code that you ripped off of.......
Olzeke51
Post by basicchip » Thu Jan 10, 2019 12:21 am
No builtin function, but constant arrays are allocated in order. so their size can be inferred from the difference between 2 addresses for the constants
