SizeOf built-in function?
TodWulff
Post by TodWulff »
Is there a built-in function that returns the number of elements in a previously dim'd int, single, byte (or other sub-word variants) arrays?
Yeah, I know I can physically count the elements in the def statements and use that with a #def, but if I neglect to do so, or forget to update the #def that reflects the def'd array element count, then I have a potential issue.
I've been cogitating on how to implement something like this programmatically as a function, but am coming up empty handed for a robust solution. Had considered using addressof for the var name and the next dim'd var, doing the math to try to figure that out, but that is a house of cards that can come down pretty quickly, I perceive.
What caused this is my stoopid little speaker test program that plays the US National Anthem (Star-Spangled Banner) that I shamelessly raped from some arduino app dev's git repo (credits are in the sources):
The SPK_defs.lib file:
#ifndef SPK_defs
#define SPK_defs
' @file:		SPK_lib.bas
' @target:		ARMbasic v7 Target
' @language:	ARMbasic
' This lib file provides #defs and other support data for making use
' of a spkr hooked to a GPIO line - in this case, it is a K1206 piezo buzzer actually
' @author Tod Wulff
' @version 1.1 - 12Aug18
'	- Updated for current rev hardware
' @version 1.0 - 29Dec08
'	- original version
'------------------------ IO Definitions --------------------------------------
#ifdef LPC824
	#define		_SPK_IO_PORT			6
#elif defined LPC54102	' ARMdrino | ARMniobe
	#define		_SPK_IO_PORT			30
The SPK_support.lib file:
#ifndef SPK_support
#define SPK_support
#include "spk\SPK_defs.lib"
' @target:		ARMbasic circa 2018 Targets
' This lib file provides support routines for making use of a speaker hooked to
' a GPIO line - in this case, it is a K1206 piezo buzzer actually...
' @author Tod Wulff
'	Revised circa 2008 code for use with circa 2018 ARMbasic devices from Coridium
'    This revision effort led me to understand that each device type has different timing models.
'    and that I will need to revise this for additional devices, beyond the LPC800-DIP (w/ LPC824).
 ' Preprocessor used to assert hard-coded constants vs using variables
#define _SPK_SwpHiFreq 5000
#define _SPK_SwpLoFreq 0
#define _SPK_SwpFreqLoopStep 100
#define _SPK_SwpMaxVol 20
#define _SPK_SwpMinVol 0
#define _SPK_SwpVolStep _SPK_SwpMaxVol
#define _SPK_SwpDur 1 'mS
#define bleep spk_beep(1500,15,25)
#define bloop spk_beep(500,15,25)
#define blip spk_beep(10000,1,1)
' FREQ 0-10,000HZ, VOL 0-50, Dur in uS
function spk_beep(spk_beep_freq as integer, spk_beep_volume as integer, spk_beep_duration as integer) as integer
'print spk_beep_freq, spk_beep_volume, spk_beep_duration
	if(if((spk_beep_freq<=0)+(spk_beep_freq>10000),1,0)+if((spk_beep_volume<=0)+(spk_beep_volume>50),1,0)+if(spk_beep_duration<=0,1,0)) then return 1
	dim spk_beep_start, spk_pulse_start, spk_pulse_period, spk_pulse_hi, spk_pulse_lo as integer
	spk_pulse_period = 1000000/spk_beep_freq
	spk_pulse_hi = spk_beep_volume * (10000/spk_beep_freq)
	spk_pulse_lo = spk_pulse_period-spk_pulse_hi
	output(_SPK_IO_PORT)
	spk_beep_start = timer
	while timer-spk_beep_start < spk_beep_duration * 1000
		'in-lined durations of 1-4 us to get best representation considering loop overheads
		'on the 824.  need to throw this code at the other family members with a scope and
		'give it a bit more robustness (#def the diff targets' timing.).
		if spk_pulse_hi=1
			out(_SPK_IO_PORT) = 1
			out(_SPK_IO_PORT) = 0
		elseif spk_pulse_hi=2
		elseif spk_pulse_hi=3
		elseif spk_pulse_hi=4
		else
			spk_pulse_start = timer
			while timer - spk_pulse_start < spk_pulse_hi
		while timer - spk_pulse_start < spk_pulse_lo
	return 0
endfunction
sub spk_sweep()
	dim freq_, vol_ as integer
	FOR vol_ = _SPK_SwpMinVol TO _SPK_SwpMaxVol STEP _SPK_SwpVolStep
		FOR freq_ = _SPK_SwpLoFreq TO _SPK_SwpHiFreq STEP _SPK_SwpFreqLoopStep
			SPK_BEEP(freq_, vol_, _SPK_SwpDur)
		NEXT freq_
		FOR freq_ = _SPK_SwpHiFreq DOWNTO _SPK_SwpLoFreq STEP _SPK_SwpFreqLoopStep
		NEXT freq_
	NEXT vol_
	FOR vol_ = _SPK_SwpMaxVol DOWNTO _SPK_SwpMinVol STEP _SPK_SwpVolStep
		NEXT freq_
		NEXT freq_
	NEXT vol_
endsub
The SPK_notes.lib file:
 * Public Constants, for making music
 ' credits: https://github.com/Jianan-Li/misc-arduino-sketches/tree/master/LEDMusicPlayer
#define SPK_Mnotes	89	' # of notes herein
#define nB0  31
#define nC1  33
#define nCS1 35
#define nD1  37
#define nDS1 39
#define nE1  41
#define nF1  44
#define nFS1 46
#define nG1  49
#define nGS1 52
#define nA1  55
#define nAS1 58
#define nB1  62
#define nC2  65
#define nCS2 69
#define nD2  73
#define nDS2 78
#define nE2  82
#define nF2  87
#define nFS2 93
#define nG2  98
#define nGS2 104
#define nA2  110
#define nAS2 117
#define nB2  123
#define nC3  131
#define nCS3 139
#define nD3  147
#define nDS3 156
#define nE3  165
#define nF3  175
#define nFS3 185
#define nG3  196
#define nGS3 208
#define nA3  220
#define nAS3 233
#define nB3  247
#define nC4  262
#define nCS4 277
#define nD4  294
#define nDS4 311
#define nE4  330
#define nF4  349
#define nFS4 370
#define nG4  392
#define nGS4 415
#define nA4  440
#define nAS4 466
#define nB4  494
#define nC5  523
#define nCS5 554
#define nD5  587
#define nDS5 622
#define nE5  659
#define nF5  698
#define nFS5 740
#define nG5  784
#define nGS5 831
#define nA5  880
#define nAS5 932
#define nB5  988
#define nC6  1047
#define nCS6 1109
#define nD6  1175
#define nDS6 1245
#define nE6  1319
#define nF6  1397
#define nFS6 1480
#define nG6  1568
#define nGS6 1661
#define nA6  1760
#define nAS6 1865
#define nB6  1976
#define nC7  2093
#define nCS7 2217
#define nD7  2349
#define nDS7 2489
#define nE7  2637
#define nF7  2794
#define nFS7 2960
#define nG7  3136
#define nGS7 3322
#define nA7  3520
#define nAS7 3729
#define nB7  3951
#define nC8  4186
#define nCS8 4435
#define nD8  4699
#define nDS8 4978
And the SPK_TEST2.bas main file (this is the one that actually plays the National Anthem):
' plays the star spangled banner
#include "spk\SPK_support.lib"
#include "spk\SPK_notes.lib"
sub playmelody
'76 elements
const SPK_Mfreqs = {
  nF5,nD5,nAS4,nD5,nF5,nAS5,nD6,nC6,nAS5,nD5,nE5,nF5,
  nF5,nF5,nD6,nC6,nAS5,nA5,nG5,nA5,nAS5,nAS5,nF5,nD5,nAS4,
  nD6,nD6,nD6,nDS6,nF6,nF6,nDS6,nD6,nC6,nD6,nDS6,nDS6,
  nDS6,nD6,nC6,nAS5,nA5,nG5,nA5,nAS5,nD5,nE5,nF5,
  nF5,nAS5,nAS5,nAS5,nA5,nG5,nG5,nG5,nC6,nDS6,nD6,nC6,nAS5,nAS5,nA5,
  nF5,nF5,nAS5,nC6,nD6,nDS6,nF6,nAS5,nC6,nD6,nDS6,nC6,nAS5
'76 elements - durations: 2 = half note, and 8/3,4,6,8,12
const SPK_Mdurations = {
  6.0,12.0, 4.0, 4.0, 4.0, 2.0, 6.0,12.0, 4.0, 4.0, 4.0, 2.0,
  8.0, 8.0, 2.76, 8.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 4.0, 4.0,
  6.0,12.0, 4.0, 4.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0,
  4.0, 2.76, 8.0, 4.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0,
  4.0, 4.0, 4.0, 8.0, 8.0, 4.0, 4.0, 4.0, 4.0, 8.0, 8.0, 8.0, 8.0, 4.0, 4.0,
  8.0, 8.0, 2.76, 8.0, 8.0, 8.0, 2.0, 8.0, 8.0, 4.0, 4.0, 4.0, 2.0
}'over the    land     of  the  free  and  the  home  of  the  brave
#define SPK_Melements (76-1) 	' the -1 adjust to a zero reference
#define SPM_MdefTempo 1500.0	'default tempo for this piece is 3000 - this is a denominator (larger # = slower tempo)
#define SPM_Volume	1			' 1 to 50 - a pseudo pwm approach - 25 a is 50% duty cycle.
dim i as integer
dim SPK_Mnote_duration as single
for i= 0 to SPK_Melements
SPK_Mnote_duration = SPM_MdefTempo/SPK_Mdurations(i)
SPK_BEEP(SPK_Mfreqs(i), SPM_Volume, (1*SPK_Mnote_duration))
wait(SPM_MdefTempo/SPK_Mdurations(i)*1.3)
out(32)=i and 1					'toggle the LED state with each note
print chr(if(i mod 2 = 0,"+","*")); '~
next i
endsub
MAIN:
output(32)						' i've an LED hooked to this gpio for visual feedback purposes only
playmelody
END
And here is the original spk_test.bas file I wrote when I was revising the spk_support.lib file:
MAIN:
dim int, freq_, vol_, dur_, lastfreq, lastvol, lastdur as integer
lastfreq = -1
lastvol = -1
lastdur = -1
'spk_sweep
	DO
		Print "Enter Freq (INT, 0-10000, <0 to exit): ";
		Debugin Freq_
		if Freq_ < 0 then exit
		if freq_ = 0 then freq_=if(lastfreq = -1, 2500, lastfreq)  ' default to 2500 or last freq
		Print Freq_;" Enter Volume (INT, 0-50): ";
		Debugin Vol_
		if Vol_ = 0 then Vol_=if(lastvol = -1, 25, lastvol)   ' default to 25 or last volume
		Print Vol_;" Enter Duration in MS (INT >0): ";
		Debugin Dur_
		if Dur_ = 0 then Dur_=if(lastdur = -1, 500, lastdur) ' default to 500 or last duration
		Print Dur_
		Print
doit:
		if(SPK_BEEP(FREQ_, VOL_, DUR_)) then Print "Error!"
		LastFreq = freq_
		LastDur = dur_
		lastvol= vol_
		Print
		Print
	LOOP
bloop
bleep
bloop
bloop
bleep
bloop
bloop
bleep
bloop
END
I'd like to be able to amend the music notes/duration arrays, and then be able to programmatically test to ensure same # of elements exist in both arrays at run-time, and have the playback loop automagically adjust to the size of the arrays at run-time.
Please advise if a sizeof exists and, if not, suggest a robust means to test an array to determine the # of elements. Thanks, in advance.
TodWulff
Re: SizeOf built-in function?
Post by TodWulff »
And yes, the 2nd piece I implement will be the Marine Corps Hymn...
Ooh Rah!
:D
Me, I would put the value in the index(0) position,
then use a 'terminator' character - as the last position or data
then run it through a for/next counting until the 'terminator' is encountered
[ascii control codes &H0 - &H1F might be a good choice - depending on your data style]
this would give you a count to compare with index(0).
'course now, my math can get messed up. on the indexing.
Just an idea.
BTW - I am shamelessly ripping off your code that you ripped off of.......
Olzeke51
No builtin function, but constant arrays are allocated in order. so their size can be inferred from the difference between 2 addresses for the constants
