PCB_PINSEL3 issue
Posted: Wed Mar 03, 2021 1:28 am
I am using the following code on a SuperPro to read the current settings in the PINSEL3 register:
m = PCB_PINSEL3
print "original = ", m
This code works correctly on a SuperPro with ARMBasic kernel version 8.08 but will only print out the "or" and then lockup on a SuperPro with ARMBasic kernel version 8.25. I also tried it on a PRO Plus with ARMBasic kernel version 8.36f and it would only print out the "or" and lockup as well. I have not been able to determine how to use the PCB_PINSEL3 with the SuperPro with the ARMBasic kernel version 8.25. Any ideas on what I am doing wrong or what could be the problem would be greatly appreciated.
m = PCB_PINSEL3
