Stacking processors
Posted: Fri Apr 28, 2023 5:39 pm
by jmcdougall
In an effort to work within a space constraint, I am looking to stack two Prostarts. How much space should I leave between them to avoid overheat issues? They will be living with an air temp of 80 - 95 degrees ambiemt temp.
Re: Stacking processors
Posted: Sun Apr 30, 2023 8:25 pm
The parts are tested to ambient temperatures of 85 C and rated to chip core temp of 150 C. (all in the NXP spec sheets)
They consume 20-30 mW so not a lot of heat generated, depends a bit on are they going to be enclosed, any air movement (ventilation holes).
I doubt there would be much of an issue, though I would probably mount them of 1/4 inch spacers.
