timer ticks ARM BASIC vs BASIC stamp
Posted: Sun Feb 10, 2013 11:09 pm
Hi all,
With the BASIC stamp the actual CLK tics need to be truncated-scaled as in (from
PERL code):
$true_secs_per_tic = ($secs_per_tic/2)*2.304;
$num_tics = int ( ($num_tics/$true_secs_per_tic) + 1 );
Are there any issues for CLK adjustment timings I should be aware of with the
ARMmite?
thanks,
t
Re: timer ticks ARM BASIC vs BASIC stamp
Posted: Sun Feb 10, 2013 11:10 pm
The TIMER in BASIC is set to increment every microsecond, no adjustment
necessary.
However, the time base for the ARMmite, PRO and ARMexpress is based on a ceramic
resonator which is 1% accurate.
The PROplus and SuperPRO use the internal oscillator which is trimmed to 1% at
NXP. But they also allow an external crystal to be added for better accuracy.
The DINkit uses an external crystal for 200 ppm accuracy.
