Super Pro Mounting Hardware
Posted: Thu Mar 14, 2013 12:36 am
by danlee58
I need insulating mounting hardware to mount my Super Pro board in an aluminum enclosure.
What size screws are needed to mount the Super Pro?
Are they avaiable in insulating material?
Re: Super Pro Mounting Hardware
Posted: Fri Mar 15, 2013 12:40 am
by danlee58
I found the hardware that I need at www.sparkfun.com.
Posted: Fri Mar 15, 2013 1:21 am
The screw holes are 0.125" and are not connected to anything on the board, so #4 in SAE or M3 in metric should be the correct bolt size.
For those of you who haven't discovered them, McMaster stocks virtually every nut, bolt, standoff and most any other hardware you will ever need.
