debugin modification
Posted: Wed Aug 06, 2014 2:19 pm
on your next update of the kernel - would it be possible to send out a "?" just before the DEBUGIN accepts input?
other terminal programs don't give any indication of an input request (ie. TclTerm.tcl)
This is similar to the old-style INPUT command.
I stick it (DEBGIN)in my program and forget about it - thinking the program has hung---
this CAN ALSO occur if the cursor happens to be in the data output (terminal) window instead of the "Enter window"
// sloppy window usage - with several windows open on the desktop - I just click in the terminal window to select it
// so I can do a 'reload file'
originally I included RXD in my suggestion - but upon further thought - if you are doing a bunch of serial data exchanges
you may not want the '?' being transmitted, whereas DEBUGIN is expected to be a one-way transfer of info
Thanx from an OL' timer
