There is a DXF file in the Schematics directory and various posts here in the forum about utilities to read that.
With the exception of the oddball Arduino 8 pin connector all others are on 0.1" centers.
Stacking Arduino Shields
Re: Stacking Arduino Shields
I downloaded JetCam (http://www.jetcam.com/free-cad-viewer.htm ), and I found the locations for the Power Connections & RESn, but the LoadC Jumper is vertical in the DXF, but on my SuperPro board, the Jumper is horizontal.
You must have installed that connector, you can bend it up or replace it if need be.
The DXF file that I have is for a SuperPro 5.0. My unit says Rev 7. There must be a difference between the location of the LoadC jumper on those versions.
Here is a photo of the Adafruit Alphanumeric Display.
P2.10 or IO(74) is the pin that needs to be held low to enter ISP mode. It is located in the same place for all revs 5 and later in the Arduino connection area. The location of this hole is the one you should use.
In addition there is a 2 pin spot that includes P2.10 and GND so that people not using the Coridium USB dongle can connect a 2 pin header there for loading C programs. The location of this 2 pin header has moved around on the various versions.
P2.10 is also connected to pin 5 often through a resistor to pin 5 on the USB dongle connection.
Although the Adafruit display works with the USB Mini-b connector, it appears that my connecting cable doesn't have the 5th wire(ID). My Logic switch that I need to implement doesn't connect through the cable.
I have some RJ-45 Jacks. I'll order some breakout boards from SparkFun. I need to maintain a small elevation to clear the housing for this device.
How about to keep moving forward get a flat-cable 5x2 connector. I have a well stocked lab and keep those around, I believe Radio Shack may still carry them. Or use an old floppy/hard drive cable from a dead PC. Seems like you have 5 pin headers at maybe both ends.
There are crimp style connectors that are single row 5 pins, I can't remember the part #s but I think the manuf is Molex, surely Amp as well but finding one of theirs would be a challenge. You might start board to wire connectors in Digikey.
I have used 4 & 6 pin Molex connectors, but they were all Crimp wire type. I need to connect to a 0.1" 5 pin header. I ordered some RJ45 breakouts from Sparkfun. I use the same board on either end of the cable, so I can use 5 center pins of the 8 pin RJ45, and as long as the RJ45 jack clears my housing, I should be OK. No need for any more modifications.
Here is the display in the housing with the logical switch & the RJ45 jack.
