Page 3 of 5
Re: Drivers Win7 for LPC11U37 "kickstarter version"
Posted: Mon Jan 22, 2018 10:05 pm
What version of BASICtools are you running? In the Help-> About?
Posted: Tue Jan 23, 2018 6:09 am
by jepalza
I can't to look it now, but i'm using the lastest versión, donwloaded from you web. (date of EXE is 11-jan-18)
Posted: Tue Jan 23, 2018 6:39 am
That should be BASICtools version 6.00. I have updated to version 6.01, only real change is to force 115 Kbaud when selecting ComXX or USBSER device.
I can't duplicate the com not available except when swapping cards or the similar on my Win7. Can you tell me what sequence you go through to see that?
Posted: Tue Jan 23, 2018 2:11 pm
Assuming you can get the same driver installed as I have (pictured a few posts ago). Then I have a new setupBASIC to install that adds some debug information, so I can see where the com avail error is happening. That BASICtools version is 6.02d
That version we can also experiment with by just changing the small TclTerm.tcl file rather than having to reinstall everything.
Posted: Tue Jan 23, 2018 4:04 pm
by robots42
Hooray - that driver worked for me with Win-7 (32) Home Premium Service Pack 1
I am running BASICtools 6.02d
that leads on to two things.
I have been trying to get Blinky to flash an LED - failure, it is as if the port is not set to output,
not with IO(LED_PIN) =
or output(LED_PIN)
using
#define LED_PIN 15
output(LED_PIN)
WHILE X<10
print X
X=X+1
print"hello"
IO(LED_PIN) = X and 1 ' IO() sets pin direction and state
print in(LED_PIN)
WAIT(300)
LOOP
the value read in alternates between -1 and 0 but the pin only stays high.
That is the same for LED_PIN set to any from 15 down to 1
hello
-1
7
hello
0
8
hello
-1
9
hello
0
However if set to 0, the value read in stays at 0 and as before the pin remains high.
hello
0
7
hello
0
8
hello
0
9
hello
0
So what needs to be done to flash an LED?
The other thing is what is this error message supposed to mean?
Error: cannot find channel named ""
BASICtools then can't load any files and the only way to carry on I have found is to close BASICtools and then restart it.
Posted: Tue Jan 23, 2018 6:08 pm
by jepalza
basicchip wrote: ↑Tue Jan 23, 2018 6:39 am
At start, all time. Drivers are correct, Windows say "LPC USB VCom Port (COM13)", BasicTools , new 6.02 versión, say "stop button", then "toggle reset", and "ser-open2, but error "Com13 not available..."
robots42 wrote: ↑Tue Jan 23, 2018 4:04 pm
Same for me.
in the menu I choose "options / serial port / refresh", at this moment, it is shown:
ser-open
ser-close
ser-open
ser-close
stopButton
toggleReset
stopButton
toggleReset
Then, push "RUN", and this is shown:
Analyzing C:/Users/joseba/DOCUME~1/Coridium/Examples/BLINKY.bas
get addresses
and "Error:cannot find channel named" appears
Using TclTerm, and push in "connect" menú:
child killed: segmentation violation
while executing
"exec idLPC $::comport"
(menu invoke)
Posted: Tue Jan 23, 2018 6:37 pm
Hello @jepalza,
where did you get this version of BasicTools??
I just downloaded this morning and only got [6.00]
TIA - Olzeke
Posted: Tue Jan 23, 2018 6:48 pm
by jepalza
olzeke51 wrote: ↑Tue Jan 23, 2018 6:37 pm
Hello @jepalza,
TIA - Olzeke
That's not me, it's "robots42", but it does not matter.
Version 6.02D is taken from here:
https://www.coridium.us/coridium/shop/s ... /s01-basic
Posted: Tue Jan 23, 2018 6:54 pm
by jepalza
basicchip, In addition to the LPC11U37, I also have three teensy (3.0, 3.1 and 3.6) and the 3.1 I have with the coridium basic "teensy31.hex" (my personality file). Well, in the "old" version of BasicTools v5.55 where I started programming the teensy 3.1, it works fine, but in the new 6.02D, it tells me the error "Teensy USB serial at Com14 no longer available".
However, in the old Basictools v5.55, the LPC does not work.
Posted: Tue Jan 23, 2018 8:03 pm
I am glad the NXP lpclink driver installer fixed your drivers, I forgot there were 32 bit Win 7 machines out there. Actually my laptop that died a couple months back ran that.
I answered the pinout question at
viewtopic.php?f=2&t=1113
