Diode D3 Blown?
Posted: Mon Nov 23, 2015 3:29 am
by danlee58
I had my SuperPro board powered through the USB connection. I inadvertently shorted the 5 Volts to ground. I think that I drew excessive current through D3. Now my board is dead.
Can It be repaired?
I could try to power it with another source through another port to see, if that works.
Re: Diode D3 Blown?
Posted: Tue Nov 24, 2015 2:42 pm
also check the traces to see if they delaminated (they have a bubbly look to them) from the pcb, and/or just plain burned up.
Been there - done that. Olzeke51
Re: Diode D3 Blown?
Posted: Tue Nov 24, 2015 7:55 pm
by danlee58
I jumpered around D3. The board is OK now. I don't need to use another power source, so this will work.
