Linux 2018
Posted: Thu Feb 08, 2018 10:23 pm
Hi y'all,
Downloaded the Feb 8,2018 Coridium.7z that was linked from the Coridium.us/Blog posting re: Linux
I ran it on my MX-17 linux machine, had some failures - BUT I have some solutions!
1. after 'extracting' the files to your 'home' folder
2. run [in a terminal]
FYI - this creates a 'dialout' group to access the USB /com ports - Reboot
3. as su or sudo run these commands from a terminal in your ~/Coridium directory
this allows you to 'execute' the different parts of BASICtools
Note: I also did it to the BASICtools.tcl and the TCLterm.tcl files - just in case
4. still as su or sudo I went to the "/user/local/bin/Coridium folder and
applied the same commands. this is probably overkill but I didn't want to spend too much time
have your board plugged in -- OR use the Help tab
5. as a normal user , goto your ~/Coridium folder and do
6. Pick your editor; unless your system has 'gedit' [out-of-box default] and you want to use it.
FWI - my editors were in /usr/bin folder -- I am currently using 'bluefish'
HAVE FUN !!!
Gary Olzeke
P.S. I want to thank @nik28200 for the impetus to do this again!! - Thanks
2. run
sudo bash installBASIC.shFYI - this creates a 'dialout' group to access the USB /com ports - Reboot
chmod +x ARMbasic
chmod +x BASICtools
chmod +x bpp'
bash BASICtoolsFWI - my editors were in /usr/bin folder -- I am currently using 'bluefish'
HAVE FUN !!!
Gary Olzeke
