I was browsing Digi-Key looking for a project box to hold an ArmMite board.
Was it designed to fit the standoffs for a specific box?
Box for ARMmite
Re: Box for ARMmite
The ARMmite was designed to fit in an extruded box, from Hammond. Hammond will
also do custom end panels for as few 10 boxes
http://www.hammondmfg.com/pdf/1455C801.pdf
Re: Box for ARMmite
Search Polycase.
Absolutely the cheapest, best case vendor I have found.
http://www.polycase.com/
They will custom drill, cut, cnc 1 box.
Good luck.
Good luck.
Re: Box for ARMmite
This is a good find, and good to know they will do a single unit, though I don't
know what their setup charges are like.
In any case the LP-21 will probably work for the ARMmite PRO, but the LP-31
would be needed for an ARMmite (the internal bosses are too close together).
FYI, when you install our tools you also get a directory called Schematics,
which has schematics in it duh, but also DXFs of the board outline and holes.
Maybe we need a better name.
Re: Box for ARMmite
PacTec CM Series top and bottom covers both are removable alogh with front and
rear panels to provide full access to board
http://www.pactecenclosures.com/Plastic ... 5-200.html
