ARMweb project in C
Posted: Tue Jan 29, 2013 2:07 am
I have a project in mind that may fit on this controller but I have a
few questions. I'd very much like to use a C or C++ compiler instead of
Basic. Basic works OK for toggling a bit or two but I like C better for
more complex operations.
So what's the status of a C compiler for this board? Where? How much?
Is there a I2C library?
Is there a one wire interface library?
What level can the ethernet port be programmed at?
Are there example ethernet server/client software available in the C
language?
As you can probably tell I want to be able to talk with devices hanging
from either a I2C bus and/or a one wire bus. And of course the ethernet
port.
Thanks for any info.
Jim.
language?
port.
Jim.
