control from an iPad
Posted: Mon Feb 11, 2013 2:30 pm
>I thought I'd post this discussion from the help line (earlier posts at the
end)
Rather than the 1K panel, I'd suggest an ARMweb, or dedicated cheap PC, or a
WizNet module. Any of these could serve a webpage, and that gives you control
from anything with a browser
Yes it would be cheaper but I want to have the touch screen that can communicate
with an i-pad and then use the i-phone app that comes with that touch screen.
There are 4 PWMs available, and you can read the 2 pots with 2 A/Ds
At 1K for a Modbus touch panel, wouldn't it be easier to talk to a PC (and
cheaper), or an Android tablet via USB?
This is what I need the MODBUS for.
http://www.automationdirect.com/adc/Sho ... ces/C-more_\
Touch_Panels/C-more_Touch_Panels_(8_inch_-_15_inch)/EA7-T8C
I'd say the SuperPRO can probably do most of what you are looking to do, with
some external support.
It's hard to access all 6 ADs as 2 are shared with debug pins (a bit of an
oversight IMHO from NXP).
And for 2 analog outputs, unless you plan to use PWM to generate them, there is
only 1 D/A and it shares a pin with an A/D
We've done some MODBUS on other parts, and know it can be done, not sure what it
would talk to in your house.
Ethernet is also something we do a lot with, with our ARMweb product, and
sometime this year we'll have a 1788 based version of that (not soon)
> Hey, I have a house with four motion
> detectors that will turn on a pump to recirculate the hot
> water when someone comes into the bathroom or kitchen. These
> motion detectors are small transistor sized three wire
> motion detectors with digital output and supply voltage from
> 2.3v-4v, MICRO MOTION DETECTOR:
> http://search.digikey.com/us/en/product ... ND/2601863
> I want to use your ARMmiteProSDK controller to run these and
> also drive two PMW controllers
> GE AF 300 mini:
http://www.wolfautomation.com/products/ ... rivebr18-t\
o-5-hpbrfuji-frenic-mini-series?gclid=CMKop9n9864CFcIFRQodR0M08w
> Sorry about all the links but I also want to run 10 digital
> inputs 12 Digital outputs /// and 6 analog inputs and 2
> analog outputs for the drivers mentioned above. Now, in a
> prefect world, I would be able to use Ethernet and
> MODBUS so I can communicate with a touch screen
> device.
> How much is possible with your little controllers and if
> I\'m crazy just tell me.
end)
> GE AF 300 mini:
> device.
