115.2 Kbaud on SuperPRO
The SuperPRO (LPC1756), DataLogger (LPC4330), BASICchip (LPC1114) use an internal PCLK of 24 MHz. For generating the baud rate clock at 115.2 Kb this is too coarse and the standard BAUD(x) call needs to be modified.
use --
#include "LPC17xx.bas"   ' or the appropriate include file
BAUD(1)=125000       ' enable UART1, standard call for 115.2 is too coarse -- needs fractional rate
UART1_FDR = &HC1     ' fractional divider of 1.083333
TXD(1) = &H33   ' print an ASCII 3
Re: 115.2 Kbaud on SuperPRO
Thanks for the update
Gary
I did have to add a delay at the end of the BASIC program, because when a BASIC program ends, all interrupts are turned off (except systick and UART0)
To compensate for that, I added a WAIT(1000) at the end of the program.
SUB PrintUART1 (Astr(100) as STRING)
    DIM I as INTEGER
    I=0
    WHILE Astr(I)
        TXD(1) =  Astr(I)
        I=I+1
    LOOP
END SUB
UART1_FDR = &HC1
for i= 1 to 10
PrintUART1 ("Hello World")       ' Send a string of characters serially out UART1
TXD(1)=13
next
wait(1000)
and now the receive side. I used a USB dongle connected to P2.1 and P2.0
    DIM I as INTEGER
    I=0
    WHILE Astr(I)
        TXD(1) =  Astr(I)
        I=I+1
    LOOP
END SUB
UART1_FDR = &HC1
for i= 1 to 10
TXD(1)=13
next
' now echo the first 10 charaters sent to UART1
x = 10
while x>0
	y = RXD(1)
	while y = -1
		y = RXD(1)		' when -1 there is no character available
	TXD(0)=y	        ' echo the character to BASICtools
	x=x-1
