Hi guys,
I've been trying to use a coridium basic chip for a high altitude ballooning project. All is well listening to the gps (ublox 6) on serial but I can't send messages to it
I'm just trying to send sentences such as the ones here http://ukhas.org.uk/guides:ublox6
ie the strings from
// Turning off all GPS NMEA strings apart from GPGGA on the uBlox modules
Serial.print("$PUBX,40,GLL,0,0,0,0*5C\r\n");
Serial.print("$PUBX,40,ZDA,0,0,0,0*44\r\n");
Serial.print("$PUBX,40,VTG,0,0,0,0*5E\r\n");
Serial.print("$PUBX,40,GSV,0,0,0,0*59\r\n");
Serial.print("$PUBX,40,GSA,0,0,0,0*4E\r\n");
Serial.print("$PUBX,40,RMC,0,0,0,0*47\r\n");
I'm sure I'm missing something basic out. Does anyone have an idea why it's not working?
my code (a little bit rough as its only testing the SEROUT)
#include <SERIAL.bas>
'SENDING DATA TO GPS
DIM BYTES(255) AS STRING
dim shortMessage(3)
INPUT(10)
bbBaud(10)=9600
OUTPUT(8)
bbBaud(8)=9600
do
BYTES=""
wait(10)
SERIN (10, 9600, 1, 255,BYTES)
PRINT BYTES
SEROUT (8, 9600, 1, 23,"$PUBX,40,GLL,0,0,0,0*5C")'1g flight mode#
'wait(10)
SEROUT (8, 9600, 1, 23,"$PUBX,40,ZDA,0,0,0,0*44")'OFF NMEA GLL
'wait(10)
SEROUT (8, 9600, 1, 23,"$PUBX,40,VTG,0,0,0,0*5E")'Switching off NMEA GSA
'wait(10)
SEROUT (8, 9600, 1, 23,"$PUBX,40,GSV,0,0,0,0*59")'Switching off NMEA GSV
'wait(10)
SEROUT (8, 9600, 1, 23,"$PUBX,40,GSA,0,0,0,0*4E")'Switching off NMEA RMC
'wait(10)
SEROUT (8, 9600, 1, 23,"$PUBX,40,RMC,0,0,0,0*47")
'wait(10)
SEROUT (8, 9600, 1, 22,"1019861802401000001143")'switching of gll
'wait(10)
'SEROUT (10, 9600, 1, 22,[$101]) 'trying to send hex, not working
'chr(101)chr(98)Chr(6)chr(1)chr(8)chr(0)chr(240)chr(1)chr(0)chr(0)chr(0)chr(0)chr(0)chr(1)chr(1)chr(43)'decimal values of the hex trying to send
'shortMessage(0)= 101
' shortMessage(1) = 98
' shortMessage(2) = 6
'SEROUT(10,9600, 1, 10, shortMessage) 'trying to send array, not working
'print shortMessage
PRINT BYTES
PRINT BYTES
PRINT BYTES
PRINT BYTES
PRINT BYTES
PRINT BYTES
LOOP
Serial to ublox 6 gps
Re: Serial to ublox 6 gps
I can't speak to the syntax to the GPS, I know others out there have used similar devices
But your ShortMessage needs to be a string or byte array, not an array of integers, and the compiler will complain about that--
The same applies to sending a hex value, it has to be stored in a STRING or BYTE ARRAY before being sent
STRINGs are special cases of BYTE ARRAYs where the STRING is terminated by a character of 0. So while you can assign a byte to be 0, you can not use chr(0) in a STRING expression
DIM xx(20)
serout (10,9600,1,19,xx)
ERROR 25: Expected string variable, found xx)
ERROR 25: Expected End Of Line, found xx)
DIM XX{20) AS BYTE
XX = "somestring" + chr(0) + "another string" ' in this case the "another string" is not added because 0 terminates the string
XX = "something" + " " + "another string"
XX{9] = 0 ' does accomplish what you want
Finally understood what you mean and have working hex serial code
SERINtimeout = 700000
dim serialarray(255) as BYTE
wait(3000)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H24)+chr(&H24)+" "+chr(&HFF)+chr(&HFF)+chr(&H06)+chr(&H03)+" "+" "+" "+" "+chr(&H10)+chr(&H27)+" "+" "'flight mode
serialarray(5)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(13)=0
serialarray(16)=0
serialarray(17)=0
SEROUT (8, 9600, 1, 17,serialarray)
wait(10)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H01)+chr(&H08)+" "+chr(&HF0)+chr(&H05)+" "+" "+" "+" "+" "+" "+chr(&H04)+chr(&H46)'vtg off
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(13)=0
serialarray(8)=0
wait(10)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H01)+chr(&H08)+" "+chr(&HF0)+chr(&H01)+" "+" "+" "+" "+" "+chr(&H01)+chr(&H01)+chr(&H2B)'switch off gll
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H01)+chr(&H08)+" "+chr(&HF0)+chr(&H04)+" "+" "+" "+" "+" "+chr(&H01)+chr(&H04)+chr(&H40)'off rmc
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H01)+chr(&H08)+" "+chr(&HF0)+chr(&H02)+" "+" "+" "+" "+" "+chr(&H01)+chr(&H02)+chr(&H32)'off gsa
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray=chr(&HB5)+chr(&H62)+chr(&H06)+chr(&H01)+chr(&H08)+" "+chr(&HF0)+chr(&H03)+" "+" "+" "+" "+" "+chr(&H01)+chr(&H03)+chr(&H39)'off gsv
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
print "end setting gps"
do
BYTES=""
PRINT BYTES
Print""
PRINT BYTES
Print""
wait(10)
LOOP
now it outputs
$GPGGA,014259.00,5129.92967,N,00006.60898,W,1,04,2.57,48.2,M,45.6,M,,*7D
ÿ
etc
wait(3000)
serialarray(5)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(13)=0
serialarray(16)=0
serialarray(17)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(13)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
wait(10)
serialarray(5)=0
serialarray(9)=0
serialarray(10)=0
serialarray(11)=0
serialarray(12)=0
serialarray(8)=0
do
BYTES=""
PRINT BYTES
Print""
PRINT BYTES
Print""
wait(10)
LOOP
now it outputs
ÿ
etc
