ARMweb dongle
ARMweb dongle
Hi Bruce,
I'm doing an ARMweb interface pcb for a friend and we need to know
which usb daughter board to get that will directly mate with the
armweb serial pins.
(the one which has the correct pin locations)? The sparkfun one I
bought a few months
ago didn't fit.
If there isn't one with an exact fit I will have to extend my
interface pcb to make it connect to the
armweb serial connectors, and then add the serial pins on my interface
board to connect
with the sparkfun usb board. but I don't want to do that if I can help
it.
cheers
-mike
Re: ARMweb dongle
> bought a few months
> ago didn't fit.
We designed the ARMweb to use the SparkFun board, then SparkFun went and
redesigned it and moved the holes 0.05"
The USB dongle we built for the ARMmite PRO can be stuffed with connections for
the ARMweb, so that's the medium term solution. While we don't have that in the
store, it ships with the ARMweb evaluation kit, or can be special ordered for
now.
The long term solution is to design to the 6 pin header of the ARMmite PRO.
