I'm trying to read serial data from my ARMmite from Python...
I use BASICtools to load the led.BAS (below)
Sample test prog :
for i=1 to 3
print i
io(15)=i and 1 ' toggle the LED
wait (1000)
next i
I then run test.py (below) from a DOS box, and I get the following:
E:\Program Files\Coridium\Python>python test.py
0 à
1
2 à
3 à à à
4 à
5 à à
6 à
7 à à
8
9 à à à à à ààààà à àà ààààà àààà àààà ààà à
à à à à à à à à à à à à à à à à ààààà à àà ààààà àààà àààà ààà à
81 'bytes'
So, what am I doing wrong, or need to set?
I looked over TclTerm.tcl, and thought I had some idea, but apparently not.
If the baud is 57600 I only get 71 bytes, anything over returns 81.
Interestingly, I can set the baud up to 2**27-2 before it refuses open().
I'd also like to send control chars to the ARMmite to toggle GPIOs etc., so I'll
need to send as well...
-Ray
# test.py
import serial
import time
## Open the port. Specify baudrate and handshake.
## a running program BASIC will stop
#ser = serial.Serial(port,baudrate=rate,timeout=0,xonxoff=1)
ser = serial.Serial('COM5',
baudrate=115200,
bytesize=serial.EIGHTBITS,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
timeout=0,
xonxoff=0,
rtscts=0,
interCharTimeout=None)
## Enable the ARMmite.
## Deassert Request to Send, which enables Data Carrier Detect
## which alerts the ARMmite of a serial connection.
## RTS is used to control C loading vs BASIC load/run.
## It should always be high for a BASIC program, low for pyserial control
ser.setRTS(0)
## Deassert Data Terminal Ready which deasserts reset.
## DTR is used to reset the ARMmite (reset= 1, running = 0)
ser.setDTR(0) ## run loaded code
ser.write('%s' % (str(arg)))
i = 0
s = ''
while time.clock()<5:
buf = ser.read(ser.inWaiting())
if buf!='':
print i, buf
s += buf
i += 1
print s
print "%d 'bytes'" % len(s)
## Toggle the ARMmite reset. The program will stop.
ser.setDTR(1)
## Close the serial port. The program will resume!
ser.close()
Python serial link
Re: Python serial link
> baudrate=115200,
try 19200
> baudrate=115200,
try 19200
> > baudrate=115200,
> try 19200
OK, that works
I also got serial input to ARM:
print "Echo chamber:";
DO
debugin a
IF a MOD 2 THEN
io(15) = 1
ELSE
io(15) = 0
ENDIF
wait (500)
LOOP
import serial
import time
ser = serial.Serial('COM5', baudrate=19200, bytesize=serial.EIGHTBITS,
parity=serial.PARITY_NONE, stopbits=serial.STOPBITS_ONE,
timeout=0, xonxoff=0, rtscts=0, interCharTimeout=None)
ser.setDTR(1)
ser.setRTS(0)
i = 0
while time.clock()<1:
if len(buf)>9:
## ECHO p to DOS command line, wait for input
inp = raw_input(buf)
ser.write('%s\n' % (str(inp))) ## write to ARM, toggle LED
if buf:
print "%s" % (buf), ## DEBUGIN echos back the char
i += 1
inp = raw_input(">>")
else:
time.sleep(.0001)
ser.setDTR(1)
ser.close()
I also wrote an FFT and an RFT for ARMBASIC, if anyone's interested...
If you touch AD0 you can see the power jump in the nearest bin.
> > baudrate=115200,
> try 19200
OK, that works
DO
debugin a
IF a MOD 2 THEN
io(15) = 1
ELSE
io(15) = 0
ENDIF
wait (500)
LOOP
import serial
import time
ser.setDTR(1)
ser.setRTS(0)
i = 0
if len(buf)>9:
if buf:
i += 1
else:
time.sleep(.0001)
ser.setDTR(1)
ser.close()
Am interested in FFT code in Basic...
Thanks
Anjin
Thanks
Anjin
