RS-485 or shared serial lines
Posted: Tue Apr 01, 2014 7:34 pm
>I've seen almost nothing on the forum about RS485.
>It would be much to my advantage on an upcoming project if I could do a multi-drop RS485 network.
>It must be fully interrupt-driven, with any higher-level protocol being managed transparently, so that all I must do is examine i/o buffers from time-to-time to discern the states of the various processors on the net.
>I will have five SuperPros in a 'symbiotic' array, where each one's activities are dependent upon the states of the other four.
>I already did this with RS232 in another machine, but it requires a 'central communications processor' to handle all the dispatches. It would be 'handier' to have all the boards chatting freely among themselves, to be moving only binary status words, instead of text messages or blocks of encoded data, and having each processor containing a local table of all the other processors' states, at any given time.
>I did a lot of syncronous communications coding in decades past... but it has been decades, so any code samples of NXP17xx RS485 multi-drop would be helpful.
What it sounds like you want is a multidrop masterless network. While this can be done, it is probably not worth the time to debug. You would have to handle collision detect and backoff if you go multi-master, or come up with some token passing scheme, and then handle error conditions. Now I'm not saying it is impossible, as UART1 supports RS-485 with a transmit enable pin, which you could use by setting the appropriate control bits AFTER you set the BAUD in BASIC, as after that the firmware only accesses status, interrupt and data registers.
I recently had to do a data gathering with 4 CPUs (in this case LPC1549s) talking serially to a PC (via USB). As this was a one of a kind design, I opted for simplicity. All CPUs listen to the RXD line from the PC, but only one transmits on the TXD line at a time (they tri-state the pin when they are not selected). I used a special character to turn on one of the 4 listeners, and each could ignore the character when buried in a message if that was needed. Yes, quick and dirty and KISS. In my case the connections were short so error recovery not a big deal. So unless you want to spend a lot of time debugging, I'd suggest a master-slave arrangement with a SuperPRO managing the communication. If the cable are long RS-485 is a good way to go to nearly eliminate noise and errors, and go full-duplex (separate RX and TX pairs), and have everyone listen to the master, but only enable transmit when selected by the master.
