using all serial ports
Posted: Mon Apr 20, 2015 4:25 pm
>from help line
I am wanting to use all four hardware Uarts in my program on the SuperPro. This involves communicating with 3 motion control modules through separate RS-232 ports and also sending a continuous stream of status bytes (strings) out through the fourth UART (UART0). Going to try for 19.2kb on all systems. Handshake lines not used for any of this. (Manual suggests that using bbRxD/bbTxD on any old pins as the fourth port will lead to trouble.)
At the same time, I also want to be able to use UART0 for occasional reprogramming and debug purposes. Is this possible? It looks like you would just plug in with a cable that uses the handshake lines and this would return you to "debug mode" once ARM Tools was run. (Of course you would see the status stream as soon as the pgm started, but that's ok as long as "STOP" is independently available.)
Can you confirm this approach will work?
