HMC6352
HMC6352
The 6352 spec is pretty short on details, but what does this program do?
#define I2Cspeed100
#include
'Read the EEPROM locations
DIM astr(10) AS STRING
DIM bstr(10) AS STRING
astr = "r" ' read EEPROM
for i=0 to 8
astr(1) = i
i2cout (0,1,$42, 2, astr)
wait (1)
i2cin (0,1,$42,-1,"", 1, bstr)
print hex(bstr(0))
wait (1)
next i
According to the spec it should print
42
?? undefined
1
4
1 some value > 1
50
If this is what you see, then maybe next try writing to RAM location $7F (what
they use in their example) and see if you can read it back
									#define I2Cspeed100
#include
for i=0 to 8
astr(1) = i
wait (1)
print hex(bstr(0))
wait (1)
next i
42
?? undefined
1
4
1 some value > 1
50
Re: HMC6352
Noted. will try.
One question in the following.
HMC6352 READ addr is $43, I read your I2CIN is using addr $42, what is the
reason or just a typing mistake.
Brian
Brian
Re: HMC6352
The i2C routine will set or clear the LSB depending on a read or write, so using
$42 or $43 has the same result.
> > wait (1)
This separation of write and read is needed for the 6352 because it is REALLY
SLOW.
For most i2c devices this could be done with
i2cin (0, 1, $42, 2, astr, 1, bstr)
which would do the write of command and read back of the data in a single
operation.
> > wait (1)
SLOW.
operation.
Re: HMC6352
Note that the program will clear LSB. Already use the following program and
checking very carfully.
1) The voltage source using 3.3V instead
2) Read and Write already seperate in two lines
3) Make sure all grounding is link together
4) the result is still, all the reading from EEPROM is 00
As I show on my video, the ARMite is sending some signal and receiving somthing
from the digital compass. But the result is not correct.
Re: HMC6352
As far as I know there are no known problems with the i2c routines in BASIC or C
for the ARMmite. It has been used to interface to numerous other devices. The
C routines were used extensively for a testjig for an IC verification platform,
and the BASIC was based on that code. The routines do not support slave clock
stretching, but that can be added to the code (it does not look to be the issue
here).
I am blocked from looking at your scope captures here, and attachments are
stripped from messages to the group.
Does the data you see on the scope correspond to what the ARMmite reports?
You can always look at the source code in BASIC in the BASIClib directory.
You might check the SparkFun Forum, there are a huge number of posts on the
HMC6352.
here).
HMC6352.
Re: HMC6352
>The routines do not support slave clock stretching, but that can be added to
the code (it does not look to be the issue here).
update at 11
looks like this may be the issue
http://forum.sparkfun.com/viewtopic.php ... ht=hmc6352
to add clock stretching in BASIClib/I2C.bas
everywhere you see
INPUT SCLpin ' release SCL high
replace with
INPUT SCLpin
WHILE IN(SCLpin) = 0
LOOP
I will make this a macro at some point and add it to the source
update at 11
everywhere you see
replace with
INPUT SCLpin
LOOP
Re: HMC6352
Running C and I have the C source . We just pulled out the I2C code - to
work with separately - will look for a place to put the jpg scope traces. I
don't see that stretching is required looking at the HMC6352 spec sheet.
Bill
Bill
Re: HMC6352
> Got it working with the code below - Note the change of read 8 bits to 10
> bits - must be a stop/start bit issue. No sure if the clock stretching is
> needed. Should be able to work back to a minimum changed code, but moving on
> to other code development since this works and this device is only in our
> prototype board. We are using a different SPI device going forward.
My guess (I don't have the HMC6352) is that the HMC6352 is slow to respond, and
you have effectively slowed the ARM read down so it works. Though how reliably,
I couldn't guess.
Making it a 10 bit read for i2c WILL break for other i2c devices.
There are not start/stop bits like a serial port, but start and stop conditions
where there are transitions on SDA while SCL is high
I couldn't guess.
Re: HMC6352
I agree - an ugly hack that only makes the HMC6352 work, but I only have
this I2C device in this prototype - so works for me. The 2 extra clocks
could be just a two clock wait for the device to respond.
The HMC6352 manual shows two clock ticks between the M_SDA high and the
S_SDA low on a data transfer
Re: HMC6352
Read thru your comments. Is that means this is not possible to read the
HMC6352 by ARMbassic yet.
Brian
Brian
