I want to use the hardware serial bus so I don't run the risk of geting
"locked-up" with the software bus.
The main killer problem is the total lack of a clock line?
I'm a fairly newbe and feel lost by this . . . Help?
using the SPI peripheral
Re: using the SPI peripheral
You can enable the SPI hardware by direct reads to those registers, details in
the NXP user manual.
The basic steps are
turn on the device in SCB_PCONP
enable the SPI connection to the pins in a PINSEL register
then start programing the SPI
typically you enable it, chose the mode, and clock rate (the clock is
automatically generated for you based on the 15 MHz PCLK)
write to the SPI FIFO
either poll for done or setup an interrupt
Anyone have a code example out there?
The basic steps are
For more information and code examples see the NXP Application Notes:
AN10369: UART/SPI/I2C code examples
AN10406: Accessing SD/MMC card using SPI on LPC2000
http://ics.nxp.com/support/documents/mi ... pe=appnote
Regards,
Chris Burrows
Astrobe v3.2: LPC2xxx Oberon-07 Development System
http://www.astrobe.com
Regards,
Chris Burrows
I also cant seam to get hardware spi to work. this is the code im trying
SCB_PCONP |= (1<<8); // enable spi hardware
PCB_PINSEL0 |= 0x5500; // configure SPI0 pins
SPI_SPCCR = 0x8; // SCK = 1 MHz, counter > 8 and even
SPI_SPCR = 0x20; // Master, no interrupt enable
WAIT(100);
while(1)
SPI_SPSR = 0;
// send data
SPI_SPDR = 0x9F;
// wait for transfer to be completed
while( 0==(SPI_SPSR & 0x80) )
//WAIT(100);
//printf("%x \r",SPI_SPSR);
break;
i cant see what im missing? id expect it to send the byte and just drop out the
while loop. but it never drops out
WAIT(100);
while(1)
SPI_SPSR = 0;
// send data
SPI_SPDR = 0x9F;
//WAIT(100);
break;
solved my problem, the SSEL pin has to be held high!
Iv adapted a Dataflash AT45DBXX1D library that was written for the Arduino to
work for the arm lpc21xx using hardware SPI
It seams to work great
, email me if you want a copy, this Atmel Dataflash is
a great little chip
russdx@dsl.pipex.com
a great little chip
