CMPS03 interface
Posted: Mon Oct 29, 2012 11:49 pm
> I got the CMPS03 working great reading pulse width mode.
You may be running faster than the CMPS03 can handle.
from the CMPS03 spec --
At speeds above around 160KHz the CPU cannot respond fast enough to
read the I2C data. Therefore a small delay of 50uS should be inserted
either side of writing the register address. No delays are required
anywhere else in the sequence.
You can slow the speed of the ARM I2C by placing
#define I2Cspeed100 ' before the #include <I2C.bas>
, or you could use TIMER to add the 50uS delay.
