I am using a Coridium SuperPro Pro+. I am a new user to microprocessors but
have used several microcontrollers. I need to get the clock signal out from the
Coridium board to another device. I do not see a pin I can access for this.
Does anybody know how I can tie into the clock oscillator?
CLKOUT sourcing
Re: CLKOUT sourcing
The CLKOUT pin is not available on the 80 pin LPC175x part.
You could use one of the PWM channels to produce a clock, by changing the PCLK
divider and minimum pre-scaler, up to 25 MHz is available.
Also the base board SuperPRO and PROplus use the internal 1% IRC. You can add
an external crystal and bias caps to get more accuracy.
