Micro-Mega FPU
Posted: Thu Oct 25, 2012 2:28 pm
Micromega has released software and documentation for using the uM-FPU
V3.1 floating point coprocessor with the ARMmite and ARMexpress
controllers. Details can be found at:
http://www.micromegacorp.com/armbasic.html
Advanced instructions and fast execution allows the uM-FPU V3.1 chip
to handle data from a wide range of sensors, and perform the
additional computations or data transformations required to provide
the most accurate results.
Reading GPS data is easy with the uM-FPU V3.1 chip using the new NMEA
sentence parsing capabilities. An added advantage, is that the GPS
data is then already loaded on the FPU, ready for navigation
calculations. For an example, see Application Note 39.
http://www.micromegacorp.com/appnotes.html#an39
It's been updated with an ARMmite/ARMexpress example that calculates
great circle distances.
The uM-FPU V3 IDE software, which automatically generates uM-FPU V3.1
code from math expressions, supports ARMbasic code generation.
Regards,
Cam Thompson
Micromega Corporation
Regards,
Cam Thompson
