D/A converter
Posted: Fri Jan 25, 2013 6:21 pm
Hi,
I am looking for a recommendation for 2-4 channels D/A converter for the
ARMmite.
Use Case: Automotive signal processing
Input signal 0-4.1V for the system. Need to follow 2 independent signals and
based on other inputs like rpm and speed need to modify the input signal (same
range 0-4.1V).
Looking for 10 bit resolution, 1 ms timing would be sufficient.
Fitting on the Armite development board would be a huge plus.
Also any recommendations as to how to communicate with that D/A converter (e.g.
I2C) would be very welcome.
Thx!
Oliver
ARMmite.
range 0-4.1V).
Thx!
Oliver
