5V inputs and outputs
Posted: Wed Jan 30, 2013 3:44 pm
I have a board with 5 Volt logic and a 5.0 Volt supply. I want to jumper the 5.0
Volts to an Armmite (5 - 12 V) board, and connect a signal to EINT0 (pin 14),
and output a signal from PWM8 (pin 11). The Armmite does a simple frequency
multiply using HWPWM.
Where can I connect the 5.0 source so it gets regulated to 3.3 Volts?
Do I need and special precautions when connecting a 5 volt signal to EINT0?
I believe that 3.3 Volt output is sufficent for my 5 volt output driver.
