High Current Drivers
Posted: Fri Feb 01, 2013 5:25 am
I need to drive eight swimming pool valve actuators that take 24 VAC at 0.75
amps with my DINkit. The ULN2803 would work if it was only rated for 250
milli-amps. My question - is there a higher current equivalent of the 2803 (I
have searched but so far no luck) or should I use relays to drive the actuators?
Thanks - Jim
Re: High Current Drivers
Posted: Fri Feb 01, 2013 5:26 am
Hi, Jim,
I'd look at solid state relays or optocouplers driving a triac. The
solid state relay solution is cleaner, but may be more expensive.
Jim.
Posted: Fri Feb 01, 2013 5:27 am
The opto triac would be a good match, and fit into the footprints for the
opto-isolators of the DINkit.
Using the ULN2803, you would still need isolation from the 24VAC line, which you
could do with a small relay mounted either remotely or at the DINkit.
There are also solid state relays in the DIP4,6 or 8 pin form factor
something like this (lots of others) available at DigiKey
http://www.clare.com/home/pdfs.nsf/www/ ... 10_R07.pdf
Posted: Mon Feb 04, 2013 8:19 pm
What would be the best device to use for a relay driver. I was looking at a
8-Channels Darlington Sink Driver.
Depends on the relays, but the ULN2803 is usually a good choice.
Posted: Mon Feb 04, 2013 8:21 pm
Where can I get a ULN2308? I tried Mouser, Allied, Newark, and NTE cross ref.
Thanks again
Bruce was right the first time, ULN2803, Mouser stock# 595-ULN2803LN.
-MM
Posted: Mon Feb 04, 2013 8:22 pm
Thats the ticket.
Thanks guys
Don
--- In
Posted: Tue Feb 12, 2013 3:03 pm
>How do you hook up a relay to the DINkit high current drivers
I put a diagram here
- DIN.JPG (13.01 KiB) Viewed 23601 times
That shows the power/GND and relay connections. The drive circuit on the DINkit
is at
http://coridium.us/ARMhelp/scr/images/DINhiA.GIF
