Capture Error
Posted: Thu Feb 13, 2014 9:35 pm
by danlee58
I am trying to measure the Period of a pulse train with a SuperPro using Timer1 to count PCLK between Interrupts on Pin18. If I have 200 pps on pin 18, I expect to read 125000 with PCLK = 25Mhz. I seem to get 1/100 of that or 1250 PCLK Transitions in the 5msec time between transitions. I have the PR set to 0.
Re: Capture Error
Posted: Fri Feb 14, 2014 1:04 am
by danlee58
I think that the problem might be due to this code.
printf("%d\n"), Timer Count;
The Timer Count is a 32 bit value, and might overflow a 16 bit function(65535).
Re: Capture Error
Posted: Fri Feb 14, 2014 8:22 am
I think you are talking about C, and that should have produced a compile error, in which case new code was never loaded.
If it's BASIC, you should also get an error.
printf("%d\n",TIMER); //TIMER is a #define in C, not sure what your reference to Counter is and would error on the space between them
In C the a variable defined as short is limited to 65K, but type int is 32 bits
Re: Capture Error
Posted: Sun Feb 16, 2014 7:16 pm
by danlee58
Yes, it is C.
The actual code is:
printf("%d\n"), Timer_Count;
Timer_Count is a long unsigned int.
I get no Compiler Errors or Warnings.
Re: Capture Error
Posted: Mon Feb 17, 2014 10:16 am
This is cut nd paste from some code I used to measure a 1KHz incoming clock based on the IRC and capture0 of the timer. This was done on an 1800 series part, so the pin setup won't exactly be the same
void setupTIMER0 (void) {
LPC_CGU->BASE_M3_CLK = (1<<11) + (1<<24); // IRC
LPC_CCU1->CLK_M3_TIMER0_CFG = 1;
LPC_CCU1->CLK_M3_BUS_CFG = 1;
LPC_CCU1->CLK_M3_SCU_CFG =1;
LPC_SCU->SFSP0_8 = (1<<6) + 2; // TIMER0 CAP0 input
LPC_GIMA->CAP0_0_IN = (2<<4);
LPC_TIMER0->TCR = 1; // enable TIMER0
LPC_TIMER0->PR = 0; // no prescale, count on every PCLK
LPC_TIMER0->PC = 0; // no prescale, count on every PCLK
LPC_TIMER0->CCR = 5; // on CAP0 rise capture TC and set interrupt
LPC_TIMER0->CTCR = 0; // timer mode
LPC_TIMER0->IR = 0xff; // clear all interrupts
void main(void) {
setupTIMER0();
while(1)
if (LPC_TIMER0->IR & (1<<4)) { // capture event
KHZsamples[KHZindex++] = LPC_TIMER0->CR[0];
KHZindex &= MAXsample; // wrap on MAXsample samples
Re: Capture Error
Posted: Mon Feb 17, 2014 10:22 am
some code comments--
For 32 bit unsigned register values, I use unsigned int, I'd have to lookup what you get when you make it long, and I try to keep my code simple
printf("%d\n",x); // is what you want to use
while
printf("%d\n"),X; //may be almost legal, it won't do what you want
because, you want to pass the value of x to printf, which is done within the ()
expression,expression; //is legal in C, with both printf and x being expression, but it is unlikely what you want to do. I don't think I've ever used , between expression except in function calls. Remember I KISSS, 3rd S for software
The only expression; I normally use is
i++:
Re: Capture Error
Posted: Wed Feb 19, 2014 9:21 pm
by danlee58
I did a data log of the output from the printf("%d\n",x); statement. The printf function is working correctly. However the data shows ~1000 counts per interrupt. It should be 125000 to 150000 counts between interrupts. The interesting part of the data is that once-in-a-while, I get a sample that is in the right ballpark. I thought that this data was an error, since most data shows lower counts, but it is in fact the lower count data that's wrong.
I need to go over my input circuit to find out where the extra pulses are being generated.
