This code:
PRINT "Starting..."
WHILE (1)
For x = 0.0 to 10.0 step 0.100
PRINTF ("%1.4f", x)
WAIT(100)
Next x
LOOP
END
Outputs:
Welcome to ARMbasic Kernel[8.12] with Floating Point Copyright 2012, Coridium Corp.
for the SuperPro
Starting...
0.0000
. 0.1000
. 0.2000
. 0.3000
. 0.4000
. 0.5000
. 0.6000
. 0.7000
. 0.8000
. 0.9000
. 1.0000
. 1.1000
. 1.2000
. 1.3000
. 1.4000
. 1.5000
. 1.6000
. 1.7000
. 1.8000
. 1.9000
. 2.0000
. 2.1000
. 2.2000
. 2.3000
. 2.4000
. 2..5000
. 2.6000
. 2.7000
Any ideas?
printf is spitting out random decimal points
Re: printf is spitting out random decimal points
I'm kind of surprised it works at all, but I guess the compiler should maybe warn, though the code is not quite wrong.
The only variables that are auto-declared are integers, so x would be an integer, so again surprised the for loop even ended. So far had not tried to write FOR loops with floating point value, and my first test shows it does work, sometimes we luck out.
So this worked for me
dim x as single
for x=0.1 to 1.0 step 0.1
print x
printf("%1.6f",x)
next x
PS, like C the compiler does not do any type of checking for parameters passed in a printf.
So if you apply a format of a SINGLE to a variable INTEGER, you will get maybe what you didn't expect, GIGO -- garbage in garbage out.
Yea. I did actually declare x a SINGLE just didn't show all of the program.
It turns out to be the Timer Interrupt that I also had running that causes the extra decimal points, one per interrupt.
I'm not printing these decimal points.
Whats going on? I don't know.
Here's all the code.
#include "LPC17xx.bas"
#include "PULSE.bas"
#include "HWPWM17.bas"
#include "STRING.bas"
DIM x AS SINGLE '
DIM Every_x_ms AS INTEGER '
SUB ON_TIMER ( msec, dothis ) '
TIMER1_ISR = dothis + 1 ' set function of VIC
VICIntEnable = VICIntEnable or (1<<2) ' Enable interrupt
T1_MR0 = msec-1 ' set up match number of ms
T1_MCR = 3 ' Interrupt and Reset on MR0
T1_IR = 1 ' clear interrupt
T1_TC = 0 ' clear timer counter
T1_TCR = 1 ' TIMER1 Enable
ENDSUB '
INTERRUPT SUB DO_PID '
T1_IR = 1 ' Clear interrupt
ENDSUB '
FIO2DIR = FIO2DIR OR (1<<0) ' Make PWM1 (Pin 2.0) an Output...
P2(0) = 0 ' and set it low (Pump Full ON)
Every_x_ms = 1000
ON_TIMER(Every_x_ms, ADDRESSOF DO_PID) ' Control Pressure every 10ms (100/Sec)
PRINT "Starting..."
WHILE (1)
PRINTF(" %1.6f",x)
WAIT(100)
Next x
LOOP
END
