LPC812 Code help
joec
LPC812 Code help
Post by joec »
Why won't this code toggle an output pin?
The text is printed to screen on each loop, but the output never changes.
#include "LPC8xx.bas"
#define LED_PIN IOCON_PIO0_15
DIM X AS INTEGER
X = 0
DIR(LED_PIN) = 1
WHILE X<30
OUT(LED_PIN) = X AND 1 ' IO() sets pin direction and state
X=X+1
WAIT(500)
PRINT "HELLO WORLD"
LOOP
Re: LPC812 Code help
change the #define LED_PIN
#define LED_PIN 15
The keywords OUT, IN, DIR all map 0-31 to P0.0-P0.31, OUT does not set the pin direction, it only writes to a pin that is an output by IO or DIR
Use IOCON_PIO0_15 as a register pointer
x = IOCON_PIO0_15
