--- In ARMexpress@yahoogroups.com, Mike Asker <mike.asker@...> wrote:
> I then tried to update the firmware over USB and I got:
> C:\... load21xx web0733.hex 2138 com11
> Unexpected CPU type 0 should be 2103, 2106, 2136,or 2138
> Can't open file 2138
Hey Mike. It looks like you transposed the CPU-type and the .hex
file. The context of the load21xx command line should be:
load21xx 2138 web0733.hex com11
If you ever have any questions on the correct syntax of the load21xx
command line prompts, just enter load21xx with no parameters and hit
enter - it'll respond with a bunch of examples...
Take care.
Firmware update
Re: Firmware update
Hooray! That did it. After upgrading I'm now able to program over usb.
thanks
-mike
> Take care.
> -t
thanks
-mike
> Take care.
> -t
