PC relative constants for ARM must be word aligned, so to support that __ASM32__ (32 bit constant) has been added. It will word align that constant and insert it into the code.
This supported simple needs for inline assembly. Recently for multi-tasking a set of #define macros were written for a wide assortment of ARM assembly instructions was built. This gave another level of abstraction for inline assembly.
For instance
ASM_MOVI(1,98) ' loads R1 with 98Code: Select all
#define ASM_MOVI(Rdest,Imm) __ASM__(&H2000 + (Rdest<<8) + ((Imm) and &HFF))Code: Select all
'crude inline ASM for BASIC
#ifndef ASM_INLINE
#define ASM_INLINE
' first cut - bte Jan 5 2019 -- feel free to expand it -- or CORRECT it
#define REG_SP 13
#define REG_LR 14
#define REG_PC 15
' note to Bruce the destination register is on the left !! -- too many years in Motorola land
#define ASM_ADDRRR(Rdest,R1,R2) __ASM__(&H1800 + Rdest + (R1<<6) + (R2<<3))
#define ASM_SUBRRR(Rdest,R1,R2) __ASM__(&H1A00 + Rdest + (R1<<6) + (R2<<3)) ' Rdesr = R1 - R2
#define ASM_ADDRRI(Rdest,R1,Imm) __ASM__(&H1C00 + Rdest + (R1<<3) + ((Imm)<<6))
#define ASM_SUBRRI(Rdest,R1,Imm) __ASM__(&H1E00 + Rdest + (R1<<3) + ((Imm)<<6)) ' Rdesr = R1 - Imm
#define ASM_CMPI(Rdest,Imm) __ASM__(&H2800 + (Rdest<<8) + ((Imm) and &HFF))
#define ASM_ADDI(Rdest,Imm) __ASM__(&H3000 + (Rdest<<8) + ((Imm) and &HFF))
#define ASM_SUBI(Rdest,Imm) __ASM__(&H3800 + (Rdest<<8) + ((Imm) and &HFF))
' register ALU ops -- r0-7
#define ASM_AND(Rdest,Rsrc) __ASM__(&H4000 + (Rsrc<<3) + Rdest)
#define ASM_EOR(Rdest,Rsrc) __ASM__(&H4040 + (Rsrc<<3) + Rdest)
#define ASM_LSL(Rdest,Rsrc) __ASM__(&H4080 + (Rsrc<<3) + Rdest)
#define ASM_LSR(Rdest,Rsrc) __ASM__(&H40C0 + (Rsrc<<3) + Rdest)
#define ASM_ASR(Rdest,Rsrc) __ASM__(&H4100 + (Rsrc<<3) + Rdest)
#define ASM_ADC(Rdest,Rsrc) __ASM__(&H4140 + (Rsrc<<3) + Rdest)
#define ASM_SBC(Rdest,Rsrc) __ASM__(&H4180 + (Rsrc<<3) + Rdest)
#define ASM_ROR(Rdest,Rsrc) __ASM__(&H41C0 + (Rsrc<<3) + Rdest)
#define ASM_TST(Rdest,Rsrc) __ASM__(&H4200 + (Rsrc<<3) + Rdest)
#define ASM_NEG(Rdest,Rsrc) __ASM__(&H4240 + (Rsrc<<3) + Rdest)
#define ASM_CMP(Rdest,Rsrc) __ASM__(&H4280 + (Rsrc<<3) + Rdest)
#define ASM_CMN(Rdest,Rsrc) __ASM__(&H42C0 + (Rsrc<<3) + Rdest)
#define ASM_ORR(Rdest,Rsrc) __ASM__(&H4300 + (Rsrc<<3) + Rdest)
#define ASM_MUL(Rdest,Rsrc) __ASM__(&H4340 + (Rsrc<<3) + Rdest)
#define ASM_BIC(Rdest,Rsrc) __ASM__(&H4380 + (Rsrc<<3) + Rdest)
#define ASM_MVN(Rdest,Rsrc) __ASM__(&H43C0 + (Rsrc<<3) + Rdest)
' there are more combinations, but these seem most useful
#define ASM_MOVRloRhi(Rdest,RhiSrc) __ASM__(&H4640 + ((RhiSrc and 7)<<3) + Rdest)
#define ASM_MOVRhiRlo(RhiDst,Rsrc) __ASM__(&H4680 + (Rsrc<<3) + (RhiDst and 7))
' these are limited to r0-r7
#define ASM_STR(Rsrc,Rbase,Roff) __ASM__(&H5000 + Rsrc + (Rbase<<3) + (Roff<<6))
#define ASM_LDR(Rdest,Rbase,Roff) __ASM__(&H5800 + Rdest + (Rbase<<3) + (Roff<<6))
#define ASM_STRB(Rsrc,Rbase,Roff) __ASM__(&H5400 + Rsrc + (Rbase<<3) + (Roff<<6))
#define ASM_LDRB(Rdest,Rbase,Roff) __ASM__(&H5C00 + Rdest + (Rbase<<3) + (Roff<<6))
#define ASM_STRoff(Rsrc,Rbase,off) __ASM__(&H6000 + Rsrc + (Rbase<<3) + (((off) and &H7C00)<<4))
#define ASM_LDRoff(Rdst,Rbase,off) __ASM__(&H6800 + Rdst + (Rbase<<3) + (((off) and &H7C00)<<4))
#define ASM_STRBoff(Rsrc,Rbase,off) __ASM__(&H7000 + Rsrc + (Rbase<<3) + ((off)<<6))
#define ASM_LDRBoff(Rdst,Rbase,off) __ASM__(&H7800 + Rdst + (Rbase<<3) + ((off)<<6))
' SP relative
#define ASM_STR_SPI(Rdest,off) __ASM__(&H9000 + (Rdest<<8) + (off >> 2))
#define ASM_LDR_SPI(Rdest,off) __ASM__(&H9800 + (Rdest<<8) + (off >> 2))
' SP and PC calculate address
#define ASM_LDR_PC(Rdest,off) __ASM__(&HA000 + (Rdest<<8) + ((off-4) >> 2))
#define ASM_LDR_SP(Rdest,off) __ASM__(&HA800 + (Rdest<<8) + (off >> 2))
#define LIST_R0 1
#define LIST_R1 2
#define LIST_R2 4
#define LIST_R3 8
#define LIST_R4 16
#define LIST_R5 32
#define LIST_R6 64
#define LIST_R7 128
' PUSH POP
#define LIST_LR 256 'push
#define LIST_PC 256 'pop
#define ASM_PUSH(RegList) __ASM__(&HB400 + RegList)
#define ASM_POP(RegList) __ASM__(&HBC00 + RegList)
' multiple load/store
#define ASM_STMIA(Rbase,RegList) __ASM__(&HC000 + (Rbase<<8) + RegList)
#define ASM_LDMIA(Rbase,RegList) __ASM__(&HC800 + (Rbase<<8) + RegList)
' remember the PC 4 byte offset included -- probably only need a few of the following
#define ASM_BEQ(HWoff) __ASM__(&HD000 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BNE(HWoff) __ASM__(&HD100 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BCS(HWoff) __ASM__(&HD200 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BCC(HWoff) __ASM__(&HD300 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BMI(HWoff) __ASM__(&HD400 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BPL(HWoff) __ASM__(&HD500 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BVS(HWoff) __ASM__(&HD600 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BVC(HWoff) __ASM__(&HD700 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BHI(HWoff) __ASM__(&HD800 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLS(HWoff) __ASM__(&HD900 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BGE(HWoff) __ASM__(&HDA00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLT(HWoff) __ASM__(&HDB00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BGT(HWoff) __ASM__(&HDC00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLE(HWoff) __ASM__(&HDD00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BR(HWoff) __ASM__(&HE000 + (((HWoff-4)>>1) AND &H7FF))
