delays with loops
delays with loops
>from help line
>... what's driving
> me crazy at the moment is trying to get a short (1-2usec)
> delay to give the open drain clock lines enough rise
> time...
> trying something like this: void dly1() { for (x=0;
> x<100; x++) z++; } where x and z are ints
> can you explain why the compiler gives me no delay for
> this? doesn't seem to matter what the loop limit is, it
> only takes 200 nsec!
Most likely this is being optimized out by the compiler, it probably sees that z
is never used. You can verify that by looking at the ASM listing (under the
edit options)
To change that, I'd suggest making it a global variable.
Actually you could also use the TIMER to get a 1-3 uS delay, just wait for 2
ticks.
Most likely other ways to force it (maybe volatile), I'd have to open a C
manual.
While you could turn off optimization, I try not to do that.
