questionable error message??
Posted: Wed Nov 30, 2016 10:07 pm
Okay - just playing around with the SuperPro with the updated firmware
AND BT5.44 and then I loaded BT.5.55 from a today's download from the tech support page.
They both failed.
was checking out the memory map/locations for different variables --as there was a note on the S'Pro memory map
referring to "firmware before 8.15...". I am using 8.36a IIRC.
so I put in the "const w="a string" and no problems
I put in "const t$="also a string" and I get a message that "__temp.out is locked by another process...reboot may..."
That particular error message seems out of place for an improperly designed name for a CONST [the '$"].
I would expect something like this [although this is not correct either - no duplication in mentioned file].
Programming (prompt but no +*+* symbols ,just some blank lines and then the following lines)
-ERROR C:/Users/Olzeke51/AppData/Local/Temp/Coridium/__user.bas: 8: Duplicate Name
-First ERROR at line :8
(I went ahead and tried to <RUN> it anyway, and it ran what was previously loaded okay)
SO___ maybe next time you are in the BT you could look at the error path/message
when a '$' (dollar sign) is used in a CONST ; it seems okay when it is in a DIM.
BTW I do have the /TEMP/files that BT creates - error.tmp is empty!!
This is just a maybe fix -- I tend to stretch the limits!!!!!
Gary Olzeke51
I
They both failed.
Gary Olzeke51
I
