I was under the (initial) impression I could save RAM by using the CONST ... AS BYTE = {d1,d2,etc}
since the { d1,etc} is the assignment also !!
Later I see that CONST integers are kept in PC memory, but 'BYTE' and "$stings" are in RAM
to move on , I have DIM'd my arrays and manually assigned each element
CONST AS BYTE causes issues - the minute I made them INTEGER[default] all my <<<<<its on your list, again Thanks
issues went away - {GOSUBS/CALL using the array(index) as a passing parameter }
GOSUB dispSEGs(num2(0), num2(1), num2(2), num2(3), num2(4))
GOSUB dispSEGs(num0(0), num0(1), num0(2), num0(3), num0(4), num0(5))
-ERROR C:/Users/Zwanster/DOCUME~1/Coridium/prot0-dice.bas: 110: expected comma
* * * * * when USING 'AS BYTE'
-ERROR C:/Users/Zwanster/DOCUME~1/Coridium/prot0-dice.bas: 110: Expected End Of Line
