Arrays of strings
Posted: Fri Nov 16, 2018 1:20 am
by TodWulff
I am trying to implement a means to gain some verbosity in my debug code.
I have a integer variable to capture a task state - 0 = not started, 1 = idle, 2 = active, ...
I'd like to do something such as this:
const task_state_verbose(16) = {
	"Not Started",
	"Idle",
	"Active",
	"Paused"
for i = 0 to _task_count
	Print "Task ";i;" TaskState: ","",task_state(i);" - ";task_state_verbose(task_state(i))
next i
Of course I can make use of a select case construct, which I am going to do.
I am just wondering if there is such a thing as constant arrays of strings given ARMBasic has evolved quite a bit over the last 10 years.
Re: Arrays of strings
Posted: Fri Nov 16, 2018 11:34 pm
I think the closest you can get is a CONST bytearrayname, and use a multiplier on the error status index to get into the array. Kind of like the old-style flat file database. There is wasted space in memory unless you make them all the same size.
You might be able to use the PARAMARRAY to hold ADDRESSOF upto 15 messages of CONST strings. and then use your status code as a selector. (theory??) The PARAMARRY does allocate 16 long words(?) [of memory] regardless of how many items you define it with [IIRC].
I have played/used the PRAMARRY as a global. There are several 'posts' in regard to my questions and findings.
Hope this isn't a rabbit trail I am leading you on.
Gary z
Posted: Sun Nov 18, 2018 2:30 am
by TodWulff
An interesting set of approaches you've posited. ... I am all about being Alice.
Going to have to take a peek at that tonight/tomorrow.
Thank you, kind sir.
Posted: Sun Nov 18, 2018 10:03 am
by TodWulff
Ok, this works. I dislike it somewhat, as I think that there are likely better ways to do it.
But, as a proof of concept, it passes muster. Feel free to refactor and optimize.
defglobals:	' these are the global variables
	dim task_state_verbose_ptr (4) as integer
	return
sub init()	' init the array of strings - hokey shites here, but it works as a poc
	gosub defglobals
	dim task_state_verbose1(16) as string
	dim task_state_verbose2(16) as string
	dim task_state_verbose3(16) as string
	dim task_state_verbose4(16) as string
	task_state_verbose1	= "Not Started"
	task_state_verbose2	= "Idle"
	task_state_verbose3	= "Active"
	task_state_verbose4	= "Paused"
	task_state_verbose_ptr(1) = addressof task_state_verbose1
	task_state_verbose_ptr(2) = addressof task_state_verbose2
	task_state_verbose_ptr(3) = addressof task_state_verbose3
	task_state_verbose_ptr(4) = addressof task_state_verbose4
	endsub
function StringViaPointer(pointer as integer) as string
	dim strg(255) as string
	dim int, idx as integer
	strg =""
	idx = 0
	do
		int = *pointer
		strg(idx)=(int and $FF)
		if strg(idx)=$00 then exit
		strg(idx+1)=(int and $FF00) >> 8
		if strg(idx+1)=$00 then exit
		strg(idx+2)=(int and $FF0000) >> 16
		if strg(idx+2)=$00 then exit
		strg(idx+3)=(int and $FF000000) >> 24
		if strg(idx+3)=$00 then exit
		idx += 4
		pointer += 4
	return strg
	endfunction
	dim i as integer
	init()
	for i = 1 to 4
		print i,StringViaPointer(task_state_verbose_ptr(i))
	next i
end
Here is the result:
Analyzing S:/_Dev/__My_Code/ARMbasic_Repo/StrArrayTest2.bas
get addresses
stopButton
toggleReset
 <= done
bpp.exe -DLPC54102 -I"S:/_Dev/__My_Code/ARMbasic_Repo" -I"C:/Users/TAJS/Documents/_Dev/ARMbasic_libs/CoridiumBASICLibs_v937" "S:/_Dev/__My_Code/ARMbasic_Repo/StrArrayTest2.bas" >C:/Users/TAJS/AppData/Local/Temp/Coridium/StrArrayTest2.bpp
Compiling C:/Users/TAJS/AppData/Local/Temp/Coridium/StrArrayTest2.bpp
ARMbasic[9.37m] on the PC  Copyright 2017, Coridium Corp.
... ( 0.56K code + 0.03K const)/416K   0.38/80K data programmed
compile done
Programming Flash *+*+
done
Executing...
1	Not Started
2	Idle
3	Active
4	Paused
... Finished in 3 ms
