Multi-tasking
Posted: Sun Jan 06, 2019 6:03 pm
While I tend to favor interrupt drive or callbacks, both are possible in BASIC. One user seemed determine to get multitasking into the BASIC. After some thinking on my part, I could see interrupts could be used to switch between tasks. So I took a look at a simple example. Using timer interrupts and separate stacks for each task, it is possible to time share them. These tasks are ones that never end. For tasks that do end, they can still be driven by interrupts and will have a higher priority if only because the time shared tasks are not blocking interrupts.
This was a first, I posted a blog entry before the forum entry.
https://www.coridium.us/coridium/blog/m ... ic-why-not
Usually deeper details will be at the forum, and discussion can happen here with users. The blog is driven by markdown, so I can post user comments to the blog, if they are in markdown.
This task switch was done with 4 lines of inline assembly, needed to copy the SP or to set the SP to the new context.
Source for the simple example below, inline ASM macros here viewtopic.php?f=9&t=1303 --
#ifdef LPC1756
#include "LPC17xx.bas"
#elif defined LPC11U37
#include "LPC11U3x.bas"
#elif defined LPC54102
#include "LPC54102.bas"
#else
#error this CPU not supported yet
#include "ASMinlineBASIC.bas"
#define MAX_TASK 4
#define INT_FRAME (17-1) ' 8 registers + lr INTSUB pushes + 8 registers of INT
#define PT_PC (INT_FRAME-1)
dim taskSP (MAX_TASK-1) ' saved SP here
dim taskTIME(MAX_TASK-1) ' in msec
task_num = 0 ' cycles through the tasks
INTERRUPT SUB TIMER1IRQ
dim x
if (task_num = -1) then
' special case on startup -- don't save the main SP
else
x = ADDRESSOF(taskSP) + (task_num<<2)
ASM_MOVRloRhi(0,REG_SP) ' r0 now has value of SP
ASM_STRoff(0,7,0) ' save it in taskSP(tasknum)
task_num += 1
if task_num = MAX_TASK then task_num = 0
ASM_LDRoff(0,7,0) ' get it from taskSP(tasknum)
ASM_MOVRhiRlo(REG_SP,0) ' move SP to next task stack
T1_TC = 0 ' otherwise might be past MR0
T1_MR0 = taskTIME(task_num)-1 ' set the time alotted to the task
T1_IR = 1 ' Clear interrupt
ENDSUB
SUB ON_TIMER ( max_cnt, dothis ) ' max_cnt in msec
#if defined LPC1756 || defined LPC1751
TIMER1_ISR = dothis + 1 'set function of VIC -- need the +1 for Thumb operation
T1_PR = 24999 '1 ms prescale
VICIntEnable or= (1<<2) 'Enable interrupt
SYSCON_SYSAHBCLKCTRL OR= (1<<10) ' enable TIMER1
VICIntEnable OR= (1<<TIMER1_IRQn) 'Enable interrupt
ASYNCAPBCLKCTRLSET = SYSCON_CLOCK_TIMER1 ' enable TIMER1
T1_PR = 12499 '1 ms prescale
VICIntEnSet0 = (1<<TIMER1_IRQn) 'Enable interrupt
#else
#warning -- need special setup for this CPU
T1_MR0 = max_cnt-1 ' set up match number of ms
T1_MCR = 3 ' Interrupt and Reset on MR0
T1_IR = 1 ' clear interrupt
T1_TC = 0 ' clear timer counter
T1_TCR = 1 ' TIMER1 Enable
ENDSUB
#define STACK_SZ 127 ' probably don't need this much room -- each task needs a seperate stack
DIM stack0 (STACK_SZ)
DIM stack1 (STACK_SZ)
DIM stack2 (STACK_SZ)
DIM stack3 (STACK_SZ)
' tasks can not share subroutines/functions that have parameters or locals, as those are NOT re-entrant
sub task0
while 1 ' tasks SHALL NEVER return -- equivalent of crossing the streams
IO(6)=0
IO(6)=1
' if we do finish early someday -- a software interrupt could be used ???
end sub
sub task1
while 1
IO(7)=0
IO(7)=1
end sub
sub task2
while 1
IO(8)=0
IO(8)=1
end sub
sub task3
while 1
IO(9)=0
IO(9)=1
end sub
task_num = -1 ' special case for initial task
taskTIME(0) = 50 ' time in msec for each task
taskTIME(1) = 10
taskTIME(2) = 15
taskTIME(3) = 20
taskSP(0) = ADDRESSOF(stack0) + (STACK_SZ-INT_FRAME)*4
stack0(STACK_SZ) = &H61000000 ' seems to be initial PSR
stack0(STACK_SZ-1) = ADDRESSOF(task0) + 1
stack0(STACK_SZ-8) = &HFFFFFFF9 ' INTERRUPT SUB pushes LR here
taskSP(1) = ADDRESSOF(stack1) + (STACK_SZ-INT_FRAME)*4
stack1(STACK_SZ) = &H61000000 ' seems to be initial PSR
stack1(STACK_SZ-1) = ADDRESSOF(task1) + 1
stack1(STACK_SZ-8) = &HFFFFFFF9 ' INTERRUPT SUB pushes LR here
taskSP(2) = ADDRESSOF(stack2) + (STACK_SZ-INT_FRAME)*4
stack2(STACK_SZ) = &H61000000 ' seems to be initial PSR
stack2(STACK_SZ-1) = ADDRESSOF(task2) + 1
stack2(STACK_SZ-8) = &HFFFFFFF9 ' INTERRUPT SUB pushes LR here
taskSP(3) = ADDRESSOF(stack3) + (STACK_SZ-INT_FRAME)*4
stack3(STACK_SZ) = &H61000000 ' seems to be initial PSR
stack3(STACK_SZ-1) = ADDRESSOF(task3) + 1
stack3(STACK_SZ-8) = &HFFFFFFF9 ' INTERRUPT SUB pushes LR here
ON_TIMER (taskTIME(0), ADDRESSOF(TIMER1IRQ))
print hex(ASYNCAPBCLKCTRL), hex(SYSCON_CLOCK_TIMER1)
while 1 ' never comes back here after the first timer IRQ
