BASIC inline ASM / assembler
Posted: Sun Jan 06, 2019 7:38 pm
BASIC has always supported a rudimentary inline assembler using __ASM__(code_value). It would place that code_value into the compiled hex for the BASIC program. Code_value is typically a 2 byte value, but if the number exceeds &HFFFF then 2 instructions will be inserted into the hex.
PC relative constants for ARM must be word aligned, so to support that __ASM32__ (32 bit constant) has been added. It will word align that constant and insert it into the code.
This supported simple needs for inline assembly. Recently for multi-tasking a set of #define macros were written for a wide assortment of ARM assembly instructions was built. This gave another level of abstraction for inline assembly.
For instance
this is accomplished with this macro
This is part of the ASMinlineBASIC.bas file. Feel free to extend it or tweak the syntax (please repost here, TIA)
For instance
ASM_MOVI(1,98) ' loads R1 with 98Code: Select all
#define ASM_MOVI(Rdest,Imm) __ASM__(&H2000 + (Rdest<<8) + ((Imm) and &HFF))Code: Select all
'crude inline ASM for BASIC
#ifndef ASM_INLINE
#define ASM_INLINE
' first cut - bte Jan 5 2019 -- feel free to expand it -- or CORRECT it
#define REG_SP 13
#define REG_LR 14
#define REG_PC 15
' note to Bruce the destination register is on the left !! -- too many years in Motorola land
#define ASM_ADDRRR(Rdest,R1,R2) __ASM__(&H1800 + Rdest + (R1<<6) + (R2<<3))
#define ASM_SUBRRR(Rdest,R1,R2) __ASM__(&H1A00 + Rdest + (R1<<6) + (R2<<3)) ' Rdesr = R1 - R2
#define ASM_ADDRRI(Rdest,R1,Imm) __ASM__(&H1C00 + Rdest + (R1<<3) + ((Imm)<<6))
#define ASM_SUBRRI(Rdest,R1,Imm) __ASM__(&H1E00 + Rdest + (R1<<3) + ((Imm)<<6)) ' Rdesr = R1 - Imm
#define ASM_CMPI(Rdest,Imm) __ASM__(&H2800 + (Rdest<<8) + ((Imm) and &HFF))
#define ASM_ADDI(Rdest,Imm) __ASM__(&H3000 + (Rdest<<8) + ((Imm) and &HFF))
#define ASM_SUBI(Rdest,Imm) __ASM__(&H3800 + (Rdest<<8) + ((Imm) and &HFF))
' register ALU ops -- r0-7
#define ASM_AND(Rdest,Rsrc) __ASM__(&H4000 + (Rsrc<<3) + Rdest)
#define ASM_EOR(Rdest,Rsrc) __ASM__(&H4040 + (Rsrc<<3) + Rdest)
#define ASM_LSL(Rdest,Rsrc) __ASM__(&H4080 + (Rsrc<<3) + Rdest)
#define ASM_LSR(Rdest,Rsrc) __ASM__(&H40C0 + (Rsrc<<3) + Rdest)
#define ASM_ASR(Rdest,Rsrc) __ASM__(&H4100 + (Rsrc<<3) + Rdest)
#define ASM_ADC(Rdest,Rsrc) __ASM__(&H4140 + (Rsrc<<3) + Rdest)
#define ASM_SBC(Rdest,Rsrc) __ASM__(&H4180 + (Rsrc<<3) + Rdest)
#define ASM_ROR(Rdest,Rsrc) __ASM__(&H41C0 + (Rsrc<<3) + Rdest)
#define ASM_TST(Rdest,Rsrc) __ASM__(&H4200 + (Rsrc<<3) + Rdest)
#define ASM_NEG(Rdest,Rsrc) __ASM__(&H4240 + (Rsrc<<3) + Rdest)
#define ASM_CMP(Rdest,Rsrc) __ASM__(&H4280 + (Rsrc<<3) + Rdest)
#define ASM_CMN(Rdest,Rsrc) __ASM__(&H42C0 + (Rsrc<<3) + Rdest)
#define ASM_ORR(Rdest,Rsrc) __ASM__(&H4300 + (Rsrc<<3) + Rdest)
#define ASM_MUL(Rdest,Rsrc) __ASM__(&H4340 + (Rsrc<<3) + Rdest)
#define ASM_BIC(Rdest,Rsrc) __ASM__(&H4380 + (Rsrc<<3) + Rdest)
#define ASM_MVN(Rdest,Rsrc) __ASM__(&H43C0 + (Rsrc<<3) + Rdest)
' there are more combinations, but these seem most useful
#define ASM_MOVRloRhi(Rdest,RhiSrc) __ASM__(&H4640 + ((RhiSrc and 7)<<3) + Rdest)
#define ASM_MOVRhiRlo(RhiDst,Rsrc) __ASM__(&H4680 + (Rsrc<<3) + (RhiDst and 7))
' these are limited to r0-r7
#define ASM_STR(Rsrc,Rbase,Roff) __ASM__(&H5000 + Rsrc + (Rbase<<3) + (Roff<<6))
#define ASM_LDR(Rdest,Rbase,Roff) __ASM__(&H5800 + Rdest + (Rbase<<3) + (Roff<<6))
#define ASM_STRB(Rsrc,Rbase,Roff) __ASM__(&H5400 + Rsrc + (Rbase<<3) + (Roff<<6))
#define ASM_LDRB(Rdest,Rbase,Roff) __ASM__(&H5C00 + Rdest + (Rbase<<3) + (Roff<<6))
#define ASM_STRoff(Rsrc,Rbase,off) __ASM__(&H6000 + Rsrc + (Rbase<<3) + (((off) and &H7C00)<<4))
#define ASM_LDRoff(Rdst,Rbase,off) __ASM__(&H6800 + Rdst + (Rbase<<3) + (((off) and &H7C00)<<4))
#define ASM_STRBoff(Rsrc,Rbase,off) __ASM__(&H7000 + Rsrc + (Rbase<<3) + ((off)<<6))
#define ASM_LDRBoff(Rdst,Rbase,off) __ASM__(&H7800 + Rdst + (Rbase<<3) + ((off)<<6))
' SP relative
#define ASM_STR_SPI(Rdest,off) __ASM__(&H9000 + (Rdest<<8) + (off >> 2))
#define ASM_LDR_SPI(Rdest,off) __ASM__(&H9800 + (Rdest<<8) + (off >> 2))
' SP and PC calculate address
#define ASM_LDR_PC(Rdest,off) __ASM__(&HA000 + (Rdest<<8) + ((off-4) >> 2))
#define ASM_LDR_SP(Rdest,off) __ASM__(&HA800 + (Rdest<<8) + (off >> 2))
#define LIST_R0 1
#define LIST_R1 2
#define LIST_R2 4
#define LIST_R3 8
#define LIST_R4 16
#define LIST_R5 32
#define LIST_R6 64
#define LIST_R7 128
' PUSH POP
#define LIST_LR 256 'push
#define LIST_PC 256 'pop
#define ASM_PUSH(RegList) __ASM__(&HB400 + RegList)
#define ASM_POP(RegList) __ASM__(&HBC00 + RegList)
' multiple load/store
#define ASM_STMIA(Rbase,RegList) __ASM__(&HC000 + (Rbase<<8) + RegList)
#define ASM_LDMIA(Rbase,RegList) __ASM__(&HC800 + (Rbase<<8) + RegList)
' remember the PC 4 byte offset included -- probably only need a few of the following
#define ASM_BEQ(HWoff) __ASM__(&HD000 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BNE(HWoff) __ASM__(&HD100 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BCS(HWoff) __ASM__(&HD200 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BCC(HWoff) __ASM__(&HD300 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BMI(HWoff) __ASM__(&HD400 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BPL(HWoff) __ASM__(&HD500 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BVS(HWoff) __ASM__(&HD600 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BVC(HWoff) __ASM__(&HD700 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BHI(HWoff) __ASM__(&HD800 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLS(HWoff) __ASM__(&HD900 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BGE(HWoff) __ASM__(&HDA00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLT(HWoff) __ASM__(&HDB00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BGT(HWoff) __ASM__(&HDC00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BLE(HWoff) __ASM__(&HDD00 + (((HWoff-4)>>1) AND &HFF))
#define ASM_BR(HWoff) __ASM__(&HE000 + (((HWoff-4)>>1) AND &H7FF))
