54102_Shared_Memory
54102_Shared_Memory
I was attempting to use the M0-M4 communication memory region to pass a variable.
1) It wouldn't compile unless I used parenthesis around the CONST - [this isn't indicated in the online 'Help file' for * Pointers
2) hard faulting in the M0 - see the 'code' address [and I also ' commented it out - with good results]
M4 code
'm4 simple
print "M4 ";timer
wait(33000)
end
Re: 54102_Shared_Memory
I was able to read / write the M0 memory area &H03400600- okay
in the &H2017c0x
Tried to JUST read the M0/M4 communication memory area - got hardfault in the M0 program
the M4 had no problem writing/reading that same area
HTH
2 issues--
yes the current compiler does not recognize *const_val where const_val is defined as a BASIC const
-- been fixed here, but not released yet, we tend to use #defines for these types of constants, just the way we do it
as for the memory issue, I am not seeing that
M4 program
print "M4 here"
M0 program
wait(100)
print *&H2017c00
works fine
MY BAD - I was writing/reading a non-aligned memory address.--causing the hard fault. :oops:
Bruce caught that in an offline discussion.
[too much 8bit world in my mind/experience!!]
