ARMstamp 11U37 Systick control
Posted: Sat Oct 19, 2019 8:28 pm
Working with a MultiTasking project, I needed to turn off the SYSTICK timer using the
INTERRUPT() command. I know this is dangerous - I have 5 values to update, and
shouldn't be interrupted by the MultiTask Timer [they are TaskX timing loops; since WAIT()
shouldn't be used]....could/should I hang TIMER1
The online HELP file indicated I could do this :
What #define should I use to simulate this value?
I couldn't find this definition ST_CTRL in the LPC11U3x.bas file,
Nor the UM10462 under section 24.5.4 System timer, SysTick [page 496]
Section 18.5.1 makes reference to 'TICKINT' value [Table 346]....
Gary Olzeke51
Or you can turn on just the interrupt used by TIMER with --
INTERRUPT(0)
ST_CTRL OR= 2 ' enable the SysTick interrupt
Gary Olzeke51
