Quadrature
GKDarin
Quadrature
Post by GKDarin »
I have been searching the web looking for examples to try to implement the QEI functions.
The chunk of code below, gets you the encoder position and was mostly copied from a message on the ArmExpress Site.
The QEICAP in the Print Routine will report the number of pulses seen in the Time period specified in QEITIME and QEILOAD.
#include "LPC17xx.bas"
' Quadrature Encoder Interface Testing Program 7/19/12 DG
DIM POSITION As Integer
Dim RPM as Integer
SUB INIT
SCB_PCONP = SCB_PCONP or (1<<18) 'enable QEI bit in power/clock register (PCONP)
PCB_PINSEL3 = PCB_PINSEL3 or (1<<8) 'Set pin P1.20 mode for PH A
PCB_PINSEL3 = PCB_PINSEL3 or (1<<14) 'Set pin P1.23 mode for PH B
QEICON = QEICON or 1 'clear position
QEIMAXPOS=256 'The number of Pulses for one revolution of the encoder.
QEITIME=10000000 'Initial Sample time for
QEILOAD=10000000
ENDSUB
MAIN:
INIT
Do
POSITION = QEIPOS
Print POSITION,QEICAP
WAIT (100)
Loop
END
I'm trying to find the RPM of the encoder shaft, the documentation below describes a Variable PCLK.
My question today is:
Is there a variable in LPC17xx.bas that contains this clock value?
RPM = (PCLK * QEICAP * 60) ÷ (QEILOAD * PPR * Edges)
where:
• PCLK is the peripheral clock rate for the QEI block. See Section 4.7.3 for more on the
possibilities for PCLK).
• QEICAP is the captured velocity counter value for the last velocity timer period.
• QEILOAD is the velocity timer reload value.
• PPR is the number of pulses per revolution of the physical encoder used in the
application
• Edges is 2 or 4, based on the capture mode set in the QEICON register (2 for
CapMode set to 0 and 4 for CapMode set to 1)
Re: Quadrature
PCLK is the peripheral clock. In the PROplus and SuperPRO this is 24 MHz (1/4 of the CPU clock)
GKDarin
Re: Quadrature
Post by GKDarin »
How would one go about handling the timer overflow for the Velocity capture.
I am having trouble getting enough resolution out of the RPM calculation with the method in the above post.
I would like to have the RPM calculate in an INTERRUPT SUB each time the timer overflowed and store it in a RPM variable in the MAIN loop.
Even with QEITIME 's of 2,000,000, RPM measurements are incrementing in about 6 RPM increments.
Using a 256 pulse per rev encoder, testing at 0-600 rpm. The task at hand would actually only run at 0-150 rpm, or 38,400 pulses per second.
Would like to see RPM's calculated accurately measured down to 0.1 RPM.
Darin
GKDarin
Re: Quadrature
Post by GKDarin »
Oops, that 38400 pulses per minute, 640 per second at full speed.
Actual running speed for the important measurements would be about 300 to 500 per second.
Darin
