ARMweb include
Posted: Tue Dec 04, 2012 1:56 am
This week our focus has been on 7.33, which is a major rewrite of
various sections, many things we know about and are working on.
> This time when I try to compile a basic file it just hangs.
> Compiling oneliners works ok both from USB and ethernet.
could you give us an example of what hangs (see below though)
> Analyzing C:/Documents and Settings/mike asker/Desktop/pwm_a.bas
> processing pwm_a.bas
> It hangs at this stage, I then have to terminate the ARMbasic.exe
process.
> If I try to compile over ethernet, it hangs also.
> I also find that the ethernet hangs very frequently and stops
> responding to ping.
#include do NOT and will NOT work when loaded into the webpage for
compile. This is because where would the ARMweb go to get the
#include file?
Admittedly it should report an error, but it is ignoring that #
anything as the pre-processor inserts those lines as file markers for
line error reporting, but we should handle it better
To use #include, you should either compile using BASICtools and the
USB, or BASICtools can output a file yourname.bpp which has done all
the pre-processing, which can be forced by checking save
intermediates in the Files menu (I believe it does it automatically
when it detects its talking to a ARMweb)
> After reinstalling the software on the PC I notice that there is no
> C:/program files/coridium/temp
> directory, and C:/temp/ does not contain the intermediate files.
A Vista security change was not allowing us to write to a temp file
in the Program Files directory so we moved that to where the SET
TEMP= environment variable points to. There has been discussion of
this in the group. BASICtools 4.6 looked for the Program Files/temp
directory even though it didn't use it. 4.7 fixes this which can be
downloaded from the Coridium website (setup for BASIC)
process.
> responding to ping.
#include file?
