Text to speech
Text to speech
Hi,
Has anyone used the EMIC text to speech with Armmite controllers?
I have been trying to get the device to speak "Hello World" and get a
reply back from the device. Unfortunately, no luck with sound output
but I have been getting back data from the device.
I troubleshooted the amplified speaker with an mp3 player and they work.
The Speech board was designed with BS2 from Parallax.
I am trying to avoid using the BS2 and use the ARMmite to get this
device to work.
Anyone have any ideas?... I have provided sample code from EMIC and
provided my own code below.
Any help will be greatly appreciated!!!
Here is the sample code from EMIC:
THE Device uses 2400 baud rate.
Tx PIN 0 ' connects to Emic SIn
Rx PIN 1 ' connects to Emic SOut
Busy PIN 2 ' 1 = busy
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
Baud CON 396 ' 2400 baud, N81
#CASE BS2SX, BS2P
Baud CON 1021
#ENDSELECT
Yes CON 1
No CON 0
' Emic Commands (Hex Mode)
Say CON $00 ' say Engish text
EOM CON $AA ' end of message
OK CON $55 ' "okay" for hex mode
' -----[ Program Code
Main:
DO
GOSUB Check_Busy
SEROUT Tx, Baud, [Say, "Hello world. I am Emic. Hear me roar.", EOM]
PAUSE 2000
LOOP
END
-----[ Subroutines ]-----------------------------------------------------
' Check status of Emic TTS module
' -- wait until Busy line released by Emic
' -- code as written does not timeout
Check_Busy:
PAUSE 1 ' allow busy to activate
DO WHILE (Busy = Yes) : LOOP ' wait until not busy
RETURN
Coridium COde:
CONST YES = 1
CONST SAY = $00
CONST EOM = $AA
INPUT 2
DIM A$(10)
DIM B$(20)
A$ = "HELLO WORLD"
'------------main code-------------
MAIN:
DO
GOSUB CHKREADY
SEROUT 4, 2400,[SAY,A$,EOM] 'SEND STRING
SERIN 3,2400,[B$] 'TTSPEECH REPEATS WHAT IT SAYS
RRINT B$
WAIT(2000)
LOOP
END
'------------subroutine------------
CHKREADY:
WHILE IO(2) = YES
PRINT "WAITING..."
RETURN
