PRINT in interrrupt
Posted: Thu Dec 06, 2012 5:23 pm
I have downloaded the latest version of BasicTools but when using interrupts if
gives me the following error : "Prefetch Abort 23440004". After digging around,
I found out that the error occurs after the print statement.
Below is the interrupt I am using which works fine via the web interface but
causes the above error on BasicTools.
I am also using the latest firmware for Armweb (7.36)
**** code snippet begin ****
every20msec:
print "inside interrupt active"
return
k=0
ON TIMER 20 every20msec
sleep = (5000)
for i = 1 to 1000
j=j+1
print j
next
print "K = ", k
**** code snippet end ****
*** output begin ****
Executing...
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15inside interrupt active
*** output end ***
Is there any place where those errors are documented? Could not find anything in
the documentation under the "troubleshooting" section
every20msec:
return
k=0
sleep = (5000)
for i = 1 to 1000
j=j+1
print j
next
print "K = ", k
Executing...
1
2
3
4
5
6
7
8
9
10
11
12
13
14
*** output end ***
