--- In
ARMexpress@yahoogroups.com, "cfbsoftware1" wrote:
> --- In
ARMexpress@yahoogroups.com, "basicnode" wrote:
> > > Has anyone tried Programming any of the Coridium boards using
> this compiler?
http://www.armaide.com/
> > > (Oberon is a decendent of Pascal/Modula-2 by N. Wirth).
> > My guess is no one has tried this, however if it uses FlashMagic
> to download .hex files, it should work OK. There might be an issue
> on the original ARMmite, as it's not the easiest to hold the loadC
> (P0.14) line low during a reset.
> > This would be easy on the ARMmite PRO or ARMmite Wireless.
> Yes - FlashMagic is used.
> However, the LPC2103 is not currently included in the list of
> LPC-family devices "officially supported" by Armaide. Initial user
> feedback indicate there are some unexpected issues. Investigations
> so far indicate they are minor but needed to be tested here on an
> actual LPC2103 board.
> Consequently, an ARMite board is now on order. Once this has arrived
> and the Armaide code proven to work with it, it will be added to the
> supported list. When that has happened I'll announce it here -
> hopefully early in May.
v2.0 of Armaide has now been released, This version includes support
for the LPC2103 family of processors. All the standard examples
(including one demonstrating IEEE format 32-bit REAL arithmetic and
formatted output) have been successfully tested on the ARMmite board.
Regards
Chris Burrows
CFB Software
