Writing to Flash
Writing to Flash
I am using
DIM b(1024)
lots of stuff
WRITE ($5000,b,1024)
to copy data to Flash on an Armite.
The WRITE updates the Flash correctly for the 1st 255 values, then does not
change the rest of the previously stored values.
I have tried to duplicate the problem with a simple program and cannot.
Do you have any ideas on what might be the problem?
Re: Writing to Flash
that 1024 is a byte count, to write 1024 words use 4096
In basic there are the FREAD and WRITE functions. Is there an equivalent in C
for those functions?
Marc
check the cor_wrflash.h file
for details on the Flash organization, check the User manual from NXP.
There is a WriteFlash function in there, but I don't see a read.
You can read anywhere with pointers.
There is also a memcpy() in mem.h / mem.o
Nice to see another Armite in an automotive application. I use one for my boost
controller and another for my transmission controller.
Feeling dumb... but what would be the line of code to read with pointers?
Marc
void * memcpy (void * dst0,void * src0,unsigned int len0){
char *dst = (char *) dst0;
char *src = (char *) src0;
void * save = dst0;
while (len0--)
*dst++ = *src++;
return save;
Does anyone have some example code on how to save info and reteive info from the
flash.
