array allocation
Posted: Sun Feb 10, 2013 8:53 pm
>from help line
>I don\'t quite understand the rules of arrays in your system. I am not sure if
I should be subtracting 1 from the number of elements or adding one. Can you
please clarify?
>Example:
>I am receiving 16 bytes frames from RXD1 and I want to put them in a 16 element
array per cycle. Which would be more appropriate given the rules of ARMBasic? I
am using an ARMite PRO
>dim b(15)?
>dim b(16)?
>dim b(17)?
ARMbasic follows the Visual BASIC convention. Space is allocated from element
0, but it also allocates the last element, which goes back to earlier BASICs.
DIM B(15) ' allocates 16 elements from 0 to 15
Re: array allocation
Posted: Sun Feb 10, 2013 8:54 pm
I found Help somewhat confusing...
It says "The size is the number of elements in the array plus 1"
Is that correct?
DIM symbolname (size )
Description
DIM is used to assign arrays of integers or strings (arrays of bytes). The
size is the number of elements in the array plus 1. This allows indexing from 0
to size .
Posted: Sun Feb 10, 2013 8:55 pm
Maybe that example should use the names max and size.
And it is confusing, mainly to be backward compatible with earlier BASICs which
allocated from 1 to max. And to accomodate C like arrays which begin at 0.
If you Google Visual BASIC array allocation, from the Microsoft site
Dimension Length
The index of each dimension is 0-based, which means it ranges from 0 through its
upper bound. Therefore, the length of a given dimension is greater by 1 than the
declared upper bound for that dimension.
