BASIC compiler bug
BASIC compiler bug
Greets,
I ran into something strange, the compiler reports ENDIF without a corresponding
IF error, though I am *certain* that IF's and ENDIF's are correctly paired. (I
fixed-up the syntax differences and ran it through the VBS interpreter, so yes,
absolutely certain.)
When I comment the ENDIF line it compiles but chokes with:
FaultISR 0xFFFFFFF9
Undefined instruction fault
when I try to run it.
The board is a SuperPro, ARMbasic Kernel[8.06], compiler version 8.06f.
I boiled it down to a short repro:
#include
#include
DIM OutBuf(255) AS String
DIM LoginPhase As Integer
Dim IsLoggingIn As integer
Sub SendSerial
End Sub
Sub CompilerError
If (LoginPhase = 1) then
IsLoggingIn = 1
Print "login phase 1"
OutBuf(0) = "login"
SendSerial
' compiler error if the line below isn't commented
'End If
End Sub
MAIN:
CompilerError
Weird, yeah? It's not a big deal, I accomplished what I was trying to do....
just thought you'd want to see this.
-MM
Re: BASIC compiler bug
There is a bug in the compiler, but its in the error reporting
The line OutBuf(0) = "login"
should be OutBuf = "login"
You can't assign a string to a byte.
D'oh! I knew that. :-) I took the time to isolate it to a few lines of code,
but didn't bother re-reading those few lines carefully... took the compiler at
it's word -- but to my credit, I did go the extra mile to make sure there was no
IF block structure problem.
Just thinking off the top of my head... a type mismatch error would've been
considerably more intuitive. :-)
-MM
I appreciate the effort, it made it easy to find the error.
Version 8.08a of the compiler that fixes it has been uploaded to the files
section here. It will get into the standard release in a week or so.
