expanded memory
expanded memory
>Can sampled data be stored in Flash as well as
> SRAM on the board? That or maybe is I can send it over a serial port
> fast enough if the sample rates aren't too high, capture it via a
> terminal programs' logging function, then import into Excel.
There is limited storage on the ARMmite 5K SRAM and version 7 will
support 4-8K in Flash. So data can be sent back to the PC and there
is an example of that using Tcl on the PC and BASIC on the ARMmite-
http://www.coridiumcorp.com/ProgrammingXL.php
Another alternative is to attach a USB Flash which can be found at-
http://www.coridiumcorp.com/ProgrammingVDrv.php
Some users have also connected a CompactFlash for storage using
uALFAT-SD card
